Updated on 2026-10-28 GMT+08:00
Batch Stopping Instances on COC
In routine cloud resource management, O&M personnel often need to stop multiple cloud instances to ensure normal service running. However, when there are a large number of instances, manually stopping the instances one by one is time-consuming and error-prone. To address this challenge, COC delivers the function of centrally stopping instances in batches. With the batch shutdown function, you can stop instances one by one or in batches. This greatly improves O&M efficiency.
Precautions
  • You can perform this operation only when the selected instances are running.
  • If any service ticket (for example, an instance restart service ticket) is being executed on the selected instance, the current operation cannot be performed. Wait until the existing service ticket is complete and try again.
Billing
  • For instances that will not be billed after being stopped:
    • Basic resources (vCPUs, memory, and image) will not be charged.
    • Associated resources (EVS disks and bandwidth) will still be billed.
    • Basic resources (vCPUs and memory) will be released, so cloud server startup may fail. Wait a moment and try again.
    • Basic resources (vCPUs and memory) of instances created on a DeH or in an edge AZ will be retained.
  • For instances that will be billed after being stopped, basic resources (vCPUs, memory, and charged images) and associated resources (EVS disks and bandwidth) will still be billed after the ECSs are stopped. To stop billing, delete resources that are associated with the ECSs.
This function enables you to centrally stopping ECSs, RDS DB instances, FlexusL instances, and BMSs. You can stop a single instance or stop multiple instances at a time.
  1. Log in to COC.
  2. In the navigation pane, choose Resource O&M > Batch Resource Operations.
  3. Access the Elastic Cloud Server (ECS) tab page, click Shut Down ECSs. The ECS shutdown page is displayed.
  4. Click Add and select the target instances.
    Table 1 Parameters for selecting an instance
    Example Value
    Selection Method
    Select an instance selection method.
    • Manual Selection: Manually select one or more instances based on settings of Enterprise Project, View Type, Resource Type, Region, and Target Instance.
    • Select All: Automatically select all instances based on settings of Enterprise Project, View Type, Resource Type, Region, and Target Instance.
    Manual Selection
    Enterprise Project
    Select an enterprise project from the drop-down list. You can choose All.
    All
    View Type
    Select a view type.
    • CloudCMDB resources: Select an instance by resource type.
    • CloudCMDB application groups: Select an instance by application group.
    CloudCMDB resources
    Resource Type
    The preset value is used and cannot be changed.
    ECS
    Region
    Select a region from the drop-down list.
    CN-Hong Kong
    Target Instance
    Set filter criteria in the filter box and select the displayed instances manually or automatically.
  5. Set parameters for Batch Policy, Suspension Policy, Stop Mode, and Timeout Interval.
    Table 2 Parameter description
    Batch Policy
    Select Automatic, Manual, or No Batch.
    • Automatic: The selected instances on which you want to perform operations are automatically divided into multiple batches based on the default rule.
    • Manual: You can manually create multiple batches and add instances to each batch as required.
    • No Batch: All instances on which you want to perform operations are in the same batch.
    Suspension Policy
    You can set a target execution success rate. If the number of failed servers reaches the threshold derived from this success rate, the service ticket is flagged as abnormal and execution stops immediately.
    The success rate ranges from 0 to 100, with precision to one decimal point.
    Stop Mode
    The options are Shutdown and Forcible shutdown.
    • Shutdown: The ECS will be stopped gracefully.
    • Forcible shutdown: The ECS will be forcibly stopped, which is equivalent to directly disconnecting the power supply of the physical server. The system skips the regular process termination and data synchronization processes.
    Timeout Interval
    Maximum time threshold for the target instance to complete the shutdown process after the system delivers the shutdown command.
    The value ranges from 1 to 1800, in seconds.
  6. Click OK to go to the confirmation page. Click OK to start the execution.
    The service ticket details page is displayed.
If you stop a primary instance, its read replicas (if there are any) will also be stopped. By default, they are stopped for seven days.
  1. Log in to COC.
  3. Click the Relational Database Service (RDS) tab and click Stop RDS DB Instance. The page for stopping RDS DB instances is displayed.
    Table 3 Parameters for selecting an instance
    Example Value
    Selection Method
    Manual selection is supported.
    Manually select an instance based on settings of Enterprise Project, View Type, Resource Type, Region, and Target Instance.
    Manual Selection
    Enterprise Project
    All
    View Type
    Select a view type.
    CloudCMDB resources
    Resource Type
    RDS
    Region
    CN-Hong Kong
    Target Instance
    Set filter criteria in the filter box and select the displayed instances.
  5. Configure Batch Policy and Suspension Policy.
    • Batch Policy: Select Automatic, Manual, or No Batch.
    • Suspension Policy:
      • You can set a target execution success rate. If the number of failed servers reaches the threshold derived from this success rate, the service ticket is flagged as abnormal and execution stops immediately.
      • The success rate ranges from 0 to 100 with precision to one decimal point.
  6. Set Timeout Interval. The value ranges from 1 to 1800, in seconds.
  7. Click OK to go to the confirmation page. Click OK to start the execution.
  1. Log in to COC.
  3. Click the FlexusL tab and click Shut Down FlexusL Instances. The instance shutdown page is displayed.
    Table 4 Parameters for selecting an instance
    Example Value
    Selection Method
    Manual Selection
    Enterprise Project
    All
    View Type
    Select a view type.
    CloudCMDB resources
    Resource Type
    FlexusL
    Region
    CN-Hong Kong
    Target Instance
    Table 5 Parameter description
    Batch Policy
    Suspension Policy
    Stop Mode
    Timeout Interval
  1. Log in to COC.
  3. Click the Bare Metal Server (BMS) tab and click Shut Down BMSs. The BMS shutdown page is displayed.
    Table 6 Parameters for selecting an instance
    Example Value
    Selection Method
    Manual Selection
    Enterprise Project
    All
    View Type
    Select a view type.
    CloudCMDB resources
    Resource Type
    BMS
    Region
    CN-Hong Kong
    Target Instance
    Table 7 Parameter description
    Batch Policy
    Suspension Policy
    Stop Mode
    Timeout Interval
Viewing the Execution Records of Batch Shutdown Service Tickets
After a batch shutdown operation is performed, a resource operation service ticket record is generated to record the batch resource operation result. If you want to monitor and record the execution objects and results of a batch resource operation, you can use the resource operation ticket function.
  1. Log in to COC.
  2. In the navigation pane on the left, choose Task Management > Execution Records. The task execution records page is displayed.
  3. Click Resource Operation Service Tickets.
  4. Click the ID of the service ticket you want to view. The service ticket details page is displayed.
    On the service ticket details page, you can view the service ticket execution status, such as the start time, end time, status, and execution duration.
  5. You can also perform the operations listed in the following table based on the service ticket status.
    Table 8 Operation description
    Service Ticket Status
    Operation
    Executing
    If you want to pause the next batch when the current batch is executed, click Pause in the upper right corner.
    Click Forcibly End in the upper right corner to end the resource operation service ticket.
    Paused
    Click Continue in the upper right corner to continue the resource operation service ticket.
    Abnormal
    Click the Abnormal tab in the Execution Information area. Locate an abnormal batch and click Retry in the Operation column.
    Select an abnormal batch and click Batch Retry above the instance to re-execute all abnormal tasks in this batch.
    Click the Abnormal tab in the Execution Information area. Locate an abnormal batch and click Cancel in the Operation column.
    Select an abnormal batch and click Batch Cancel above the instance to cancel all abnormal tasks in this batch.
