- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Application and Resource Management/
Application Management/
You can associate resources with the same tag in an enterprise project with an application group for central resource management.
Associate resources with a specified application group.
Precautions
- Only after you select a group and click the Intelligent resource association button above the resource list, can this operation take effect.
- After intelligent resource association is triggered, wait until the synchronization task is executed. Time the association takes depends on the total number of resources to be associated.
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management. On the displayed page, click the Applications tab and choose a group in the resource tree in the left and click Associate with Resource.
Figure 1 Intelligently associating resources with a group
Parent topic: Application Management
