On this page
Modifying a Group
Updated on 2024-11-20 GMT+08:00
You can modify a group to facilitate resource management by group.
Modify a group on COC.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management. On the displayed page, click the Applications tab, choose a desired group in the resource tree on the left, and click .
    Figure 1 Modifying a group
  3. Set parameters in the Modify Group drawer by referring to Table 1 and click OK.
    Table 1 Parameters for modifying a group
    Example Value
    Group
    (Mandatory) Group of the component you created. Enter a valid group name.
    Test Group
    Resource Association Method
    (Mandatory) Method that is used to associate resources with the group you created. There are two association methods: manual association and intelligent association.
    • Manual: You can manually associate resources with the group you created for unified management.
    • Intelligent: You can add all resources with the same tag in an enterprise project to a resource group.
    Manual
    Enterprise Project
    (Mandatory) Enterprise project. This parameter is displayed when the resource association mode is intelligent association.
    Tag Key
    (Mandatory) This parameter is displayed if the intelligent resource association method is used.
    testKey
    Tag Value
    (Optional) This parameter is displayed if the intelligent resource association method is used.
    testValue
    Associate APM Environment
    (Optional) Configure the application, component, and environment of the APM service corresponding to the group. APM service performance information can be obtained through this field during fault diagnosis.
