Updated on 2025-09-23 GMT+08:00
Deleting a Group
After a group is created, you can delete it by following the operations in this section.
Deleting a Group
- Log in to COC.
 - In the navigation pane, choose Resources > Application and Resource Management.
 - Click Applications in the upper left corner.
 - In the application list on the left, expand the target application, select the target group, and click
. - Click OK.
The group is deleted.
