Updated on 2025-09-23 GMT+08:00
Deleting a Component
This section describes how to delete a component.
Precautions
When a component contains groups, it cannot be deleted. You can delete a node only when the node does not contain sub-nodes.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Applications in the upper left corner.
  4. In the application list on the left, expand the application, select the component to be deleted, and click .
  5. Click OK.
    The component is deleted.
