Updated on 2025-09-23 GMT+08:00
Modifying a Component
After a component is created, you can modify its name by performing the following actions.
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management.
- Click Applications in the upper left corner.
- In the application list on the left, expand the application, select the component to be modified, and click
- Set parameters for modifying a component.
Table 1 Parameters for modifying a component Parameter
Example Value
Component
Customize the component name based on the naming rule.
Test Component
- Click OK.
The component is modified.
