Updated on 2025-09-23 GMT+08:00
Deleting a Component
This section describes how to delete a component.
Precautions
When a component contains groups, it cannot be deleted. You can delete a node only when the node does not contain sub-nodes.
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management.
- Click Applications in the upper left corner.
- In the application list on the left, expand the application, select the component to be deleted, and click
. - Click OK.
The component is deleted.
