Modifying an Application
After an application is created, you can modify its name or description by performing the following operations.
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management.
- Click Applications in the upper left corner.
- In the application list on the left, select the application to be modified and click
. - Set parameters for modifying an application.
Table 1 Parameters for modifying an application Parameter
Example Value
Application
Customize an application name based on the naming rule.
Test Application
(Optional) Description of the application.
- Click OK.
The application is modified.
Modifying a Sub-application
- Log in to COC.
- In the application list on the left, select the sub-application to be modified and click
. - Set parameters for modifying a sub-application.
Table 2 Parameters for modifying an application Parameter
Example Value
Subapplication Name
Customize the sub-application name based on the naming rule.
Test sub-application
(Optional) Description of a sub-application.
- Click OK.
The sub-application is modified.
