Help Center/ CloudPond/ User Guide/ Network Connectivity/ Configuring Local Network Connectivity
Updated on 2024-09-26 GMT+08:00
Use a local gateway to connect the edge site to the on-premises system so that they can communicate with each other over a private network.
To establish network connectivity between the edge site and the on-premises system, you need to associate a VPC with the local gateway route table and add routes to the on-premises network in the route table. Test network connectivity by checking whether ECSs at the edge site can communicate with on-premises servers.
For the overall networking plan and requirements, see Overview and Networking Requirements.
The edge site is in the Available state.
Configuring Routes Between the Edge Site and the On-premises System
  2. Click in the upper left corner and select a region.
  3. Click . In the service list displayed, choose Content Delivery & Edge Computing > CloudPond, or enter CloudPond in the search box.
    The dashboard is displayed.
  4. In the left navigation pane, choose Edge Sites.
  5. Click the name of the edge site for which you want to create a VPC.
  6. In the Available Cloud Services area, locate Virtual Private Cloud and click Create.
  7. On the Create VPC page, configure the parameters.
    • Select Edge for AZ when you create a subnet.
    • For details, see Creating a VPC.
  8. Confirm the configuration and click Create Now.
  9. Click . In the service list displayed, choose Content Delivery & Edge Computing > CloudPond, or enter CloudPond in the search box.
  10. In the left navigation pane, choose Local Gateways.
  11. Locate the local gateway and click Manage Route Table in the Operation column.
  12. On the Associated VPCs tab page, click Associate VPC.
  13. In the Associate VPC dialog box, select the VPC that you just created.
  14. Click OK.
  15. On the Routes tab page, click Add Route.
  16. Configure the parameters based on Table 1.
    Table 1 Parameter description
    Example Value
    IP Address Version
    The value is fixed at IPv4. IPv6 addresses are not supported.
    Next Hop Type
    Type of the next-hop resource. The value can be VPC or Local network.
    To enable network communications between an edge site and an on-premises system, you need to configure two routes. Select a VPC as the next hop for one route and the on-premises network as the next hop for the other route.
    Next Hop
    Select the next hop.
    • If Next Hop Type is set to VPC, select the VPC to be associated with the local gateway route table.
    • If you set the Next Hop Type to Local network, select the local gateway used by the on-premises network.
    Destination
    Enter the destinations.
    • If you set Next Hop Type to VPC, enter the CIDR block of the VPC.
      You can set this parameter to the CIDR block of the subnet in the edge AZ or the CIDR block of the VPC. If you set it to the CIDR block of the VPC, the edge site connects to the on-premises network and the cloud so that the on-premises network can communicate with the cloud over a private network.
    • If Next Hop Type is set to Local network, enter the CIDR block used by your on-premises network.
    The CIDR block used by your on-premises network cannot conflict with the VPC's CIDR block.
    VPC: 10.0.3.0/24 or 10.0.0.0/16
    On-premises network: 192.168.0.0/16
  17. Click OK.
Testing Local Network Connectivity
In the following steps, a Windows ECS is used to test network connectivity.
  1. Create an ECS named ECS03 in the edge AZ and place it in VPC01 (CIDR block: 10.0.3.0/24).
  2. Locate ECS03 and record its private IP address (for example, 10.0.3.110).
  3. Log in to the on-premises server Server01 and ping ECS03.
    ping 10.0.3.110
  4. Check the command output. If the ECS can be pinged, the network connectivity has been established. If the ECS cannot be pinged, locate the cause and contact the Huawei Cloud O&M team.
Testing Network Connectivity Between the On-Premises System and the Central AZ
If you have configured a route between the central AZ and your on-premises system (you have set Destination to the CIDR block of the VPC), or if you have added a route for the subnet of the on-premises network, your on-premises system can access cloud services in the central AZ through the VPC.
  1. Create an ECS named ECS01 in the central AZ and place it in VPC01 (CIDR block: 10.0.0.0/16).
  2. Locate ECS01 and record its private IP address (for example, 10.0.1.110).
  3. Log in to the on-premises server Server01 and ping ECS01.
    ping 10.0.1.110
  4. Check the command output. If the ECS can be pinged, network connectivity has been established. If the ECS cannot be pinged, locate the cause and contact the Huawei Cloud O&M team.
