Updated on 2025-08-05 GMT+08:00
Editing a Package
Searching for a Package
  1. Go to the self-hosted repo page and click Advanced Search in the upper right corner of the page.
  2. Select the type of package to be searched for in the upper part of the page. By default, all types are selected. You can search for the package using either of the following methods:
    • Select File Name mode.
      1. Enter the keyword of the file name in the search box, and click to search for the package.
      2. In the search result list, click a file name to view the package details.
    • Select Checksums mode.
      1. Click the drop-down list on the left of the search box and select Checksums (The default value is File Name).
      2. Enter the MD5/SHA-1/SHA-256/SHA-512 checksum and click to find the desired package.
Downloading a Package
  1. Go to the self-hosted repo page. In the left pane, locate the package to be downloaded, and click its name.
    If there are too many repositories or packages, you can search for the desired one by referring to Searching for a Package.
  2. Click Download on the right of the page.
Deleting a Package
  1. Go to the self-hosted repo page. In the left pane, locate the package to be deleted, and click its name.
  2. Click Delete on the right of a package or directory in the repository to delete it.
  3. In the displayed dialog box, enter the name of the package to be deleted and click OK.
Favoriting/Unfavoriting
  1. Go to the self-hosted repo page. In the left pane, locate the package to be favorited, and click its name.
  2. Click Favorite on the right of the page.
    When the icon changes to , click My favorites in the lower left corner of the page to view the list of favorited items. Click a value in the Path column to go to the package details page.
