- What's New
- Function Overview
Getting Started
- Uploading Software Packages to Release Repos
- Uploading Components to Maven Repository
- Releasing/Obtaining a Maven Component via a Build Task
- Releasing/Obtaining an npm Component via a Build Task
- Releasing/Obtaining a Go Component via a Build Task
- Releasing/Obtaining a PyPI Component via a Build Task
- Uploading/Obtaining an RPM Component Using Linux Commands
- Uploading/Obtaining a Debian Component Using Linux Commands
User Guide
- CodeArts Artifact User Guide
- Release Repos 2.0
- Self-Hosted Repos 2.0
- Release Repos 1.0
- Self-Hosted Repos 1.0
- Whitelist for All Accounts
Best Practices
- CodeArts Artifact Best Practices
- Releasing Maven Components and Archiving to a Self-Hosted Repo
- Batch Migrating Maven/npm/PyPI Components to a Self-Hosted Repo
- API Reference
- Release Repo
Self-Hosted Repo
- How Do I Upload Snapshots to a Maven Repository?
- How Do I Pull Components from a Maven Repository?
- Can I Call Software Packages in Self-Hosted Repos During Local Builds?
- What Should I Do With Error Code 500 When Uploading Maven Package for a Gradle Build?
- Why Did the Dependency WAR or JAR Files Fail to Be Downloaded?
- Why Is Error 401 Returned When Uploading Maven Components to Self-Hosted Repos?
Show all
Configuring Clearing Policy for Maven Repository
The clearing policy allows you to automatically or manually clear artifacts in batches. This helps optimizes storage, keeps artifacts organized, and ensures they are transferred correctly during development, testing, deployment, and release.
Background
A Maven snapshot is a special version that reflects the current state of ongoing development and differs from regular versions. Maven checks for new snapshots in the remote repository with each build and allows you to set limits on how many snapshot versions to retain, as well as automatically clear out expired snapshots.
Snapshot Cleanup Policy
- Click a project card to access the project and choose Artifact > Self-hosted Repos from the navigation pane.
- Select a Maven repository (Snapshot) from the list on the left and click Settings in the upper right corner of the page.
- Click the Clearing Policies tab.
- Set the maximum number of Snapshot Count. The value ranges from 1 to 1,000.
When the number of retained snapshots exceeds the set limit, the oldest snapshot is replaced by the latest version.
- Enable automatic cleanup (No by default). Click Yes and enter the number of days. Snapshots older than the specified number of days will be automatically cleaned up.
The automatic cleanup time must be set between 1 and 100 days.
- Click Save to complete the configuration.
