Creating Manual Outbound Call Tasks
- The platform role of a user account is agent.
 - To create an outbound call task, you have completed the operations in Preparations for Creating Outbound Call Tasks.
 - At least one voice skill queue exists. For details about the configuration method, see Maintaining a Tenant Space Skill Queue. The skill queue has been associated with the agent who needs to make an outbound call. For details about the association method, see Associating an Allocated Agent ID with a Business Account and Skill Queue.
 - If the tenant space is in trial commercial use, you have contacted O&M personnel to add the numbers used for making outbound calls to the tenant space trustlist.
 - To send SMS notifications for failed outbound calls, you have configured an internal SMS template on the page. For details about how to configure an SMS notification template, see Configuring Notification Templates as an Administrator.
- Sign in to the AICC as a tenant administrator and choose .
 - Click Create and choose Manual Outbound Call.
    Figure 1 Create Agent Outbound Call
     - You can select a survey based on the version number.
 - For an outbound call task created using a template, the task type cannot be changed. Determine the outbound call task template type before creating an outbound call task.
 - Configure manual outbound call task information.
Table 1 Manual outbound call task parameters Parameter
Basic Information
Task Name
Task name, which is customized. This parameter is mandatory. The value can contain a maximum of 100 characters.
Caller Number
Calling number of the outbound call task. This parameter is mandatory. Multiple calling numbers can be selected.
The options are all access codes of the tenant space.
Call Attempts
Maximum number of call attempts. This parameter is mandatory. A failed call can be manually initiated again. When the number of call attempts reaches the maximum, unless the call is successful, the call cannot be initiated again.
The value ranges from 1 to 6.
SMS Template for Failed Outbound Call
Content of the SMS notification sent when the outbound call task fails. This parameter is optional.
Assigning Agents
Click
 to select agents in an associated voice skill queue to execute the outbound call task.If you select Specified Agent, you can specify one or more agents. Otherwise, all agents in the skill queue are selected.
Blocklist Type
If a blocklist category is selected, all numbers in this type are not called within the specified period.
Play Voice
Select the corresponding voice resources to relieve the user's waiting anxiety during a call. Play Voice: The options are prompt tones configured on the page. A maximum of 10 prompt tones can be selected.
Associate Business Result
After you associate a task with a business result, only the associated business result and its sub-business results can be selected for outbound calls in the task. If Appointment Pop-up Screen is enabled for the business result, after the business result is selected for an outbound call, the dialog box for creating a reserved outbound call task is displayed.
Automatic Extraction Rule
Whether to enable the automatic extraction rule.
After the automatic extraction rule is enabled, a specified agent can click the extraction button during a manual outbound call. 10 outbound call records that meet criteria are automatically extracted each time.
Restrictions
Business Result
Select a configured business result.
Result Fulfillment
Number of calls marked with the selected business result in the current task.
The value is a positive integer.
Completed Calls
Number of calls that need to be made before the outbound call task is complete.
The value ranges from 1 to 100000.
Single-time Claimed Quantity
Number of outbound call records extracted each time before the outbound call task is complete.
Data Extraction Conditions
Add Condition
Select And or Or.
- And: All conditions must be met.
 - Or: Any one of the conditions is met.
Add Subcondition
Add a subcondition as an additional condition.
 - (Optional) Click Save as Template. In the dialog box that is displayed, enter a template name and click confirm to save the current configuration as an outbound call template.
 - Click Save.
 - Return to the Call Mgmt page, click Contact list in the Operation column corresponding to the new outbound call task, and add outbound call data to the outbound call task. For details, see Configuring Outbound Call Data.
 - Return to the Call Mgmt page and click
 corresponding to the new outbound call task.
Follow-up Procedure
To modify an outbound call task, click Suspend to suspend it.
After the task is suspended, you can perform the following operations:
- Click Edit to modify an outbound call task.
To view the task result, you can click a task to access the outbound call task details page and view the outbound call result of each customer.
On the task result page, you can perform the following operations:
- Click Details to view all outbound call results of all called numbers under the customer.
 - Click Play to play the recording of a completed call.
 - Click
 to export the task result.
     The exported data contains personal data. Exercise caution when processing the exported data to prevent personal data leakage and abuse.
 - Click View Export Result to view the export result. On the displayed page, you can download the result.
