Viewing Outbound Call Results
- Choose , click a task, and view the outbound call result of each customer on the outbound call task details page.
    Figure 1 Outbound call results
 - Click Details to view the call details of a called number.
    Figure 2 Call Result Details
    Table 1 Parameters in the outbound call result details list Parameter
Customer ID
Customer ID, which is created when outbound call data is created.
Customer number
Customer number.
Status
Status of a call.
- Executing
 - Completed
Start Time
Time when a call starts.
End Time
Time when a call ends.
Call Attempts
Number of times that a customer number is called.
Call Result
Call result.
- Failed
 - Successful
 - Reject
Cause
Call failure cause.
Business Result Path
Business result of a call.
Business Description
Business result description.
Call ring duration
Ringing duration.
Manual call duration
Manual call duration.
IVR call duration
IVR call duration.
ACW
Wrap-up duration after a call ends.
Total call duration
Outbound call end time minus outbound call start time.
Operation
Operations that can be performed on an outbound call result.
- Business Result
 - Business Result Log
 - Play
 - Download
      - The outbound call data attributes configured in Configuring Outbound Call Data Attributes are displayed next to the Operation column.
 - Call ring duration, Manual call duration, IVR call duration, and ACW on the Completed tab page depend on the CC-CMS's function of importing CDRs to the database using the CCDIS. Therefore, you need to commission this function first. Otherwise, the values of these parameters are 0.
 - Click a task, click the Completed tab, and click
 to export task results.
Follow-up Procedure
Watermarks can be displayed on the outbound call task result page.
- Choose .
 - Choose .
 - Set watermark parameters.
- Whether to enable page watermarking: Click Edit, set Parameter Value to Yes, and click Save.
 - Page Watermark Character: Click Edit, set Parameter Value to the watermark to be displayed, and click Save.
 - Choose and view the watermark effect.
