Overview of Outbound Call Tasks
The AICC is a comprehensive outbound call management platform for enterprises. It supports the following types of outbound call tasks.
If the number of predicted outbound call tasks is greater than or equal to 4 and the number of outbound call records configured for each task is greater than or equal to 100,000, performance risks may arise when all tasks are being executed and the database is running on a server with an 8-core CPU.
Task Type |
Agent Participation (Yes/No) |
Application Scenario |
Required Resource |
Advantage |
Common IVR outbound call task |
No |
Revisit, survey, standardized information collection, or other scenarios with standard script processes. |
IVR channel |
Predicted outbound call task |
Yes |
Customer care, product marketing, and business opportunity seeking. |
Skill queue |
Intelligent robot outbound call task |
No |
Enabled intelligent IVR TTS and ASR channels |
Manual outbound call task |
Yes |
Customer care, product marketing, and business opportunity seeking |
Skill queue |
Previewed outbound call task |
Yes |
Scenarios where customer background information needs to be obtained in advance, for example, dunning tasks. |
Skill queue |
Preempted outbound call task |
Yes |
Agents are preoccupied. After a customer is connected, the call is directly connected to an agent, reducing the customer's waiting time. |
Skill queue |
Fixed outbound call task |
Yes |
Skill queue |
You can select a desired outbound call task based on the application scenarios and advantages.
The following figure shows the task states and corresponding operations in the AICC.
