Updated on 2025-11-07 GMT+08:00
SMS
You can send common SMS messages and satisfaction survey SMS messages to the calling party. The SMS messages can be Huawei Cloud SMS messages or SMS gateway messages.
Diagram Element
Figure 1 Text Message
Parameter Description
Figure 2 Common SMS message parameters
Figure 3 Satisfaction survey SMS message parameters
The parameters are described as follows:
  • Message Sending Mode: Currently, Short Message and Satisfaction Survey are supported.
    • To send a satisfaction survey SMS message, you need to set Valid Reply Period(Minutes). The value ranges from 1 to 1440.
    Figure 4 Valid Reply Period(Minutes)
  • Channel: The options are Huawei Cloud and SMS Gateway.
    • Huawei Cloud: The SMS service provided by Huawei Cloud is used to send SMS messages.
    • SMS Gateway: Huawei SMS gateway is used to send SMS messages.
  • Template: This parameter is mandatory. The administrator SMS message templates that have been configured in the notification center are displayed based on the selected channel.
  • Country Code: This parameter is mandatory. The country or region code is required for sending an SMS message. If the SMS message needs to be sent to a national number, the country or region code is also required. For example, the country code of China is +86.
  • Mobile Number: This parameter is optional. If this parameter is left empty, the SMS message is sent to the calling party by default. If this parameter is set, the SMS message is sent to the specified number. Only one number is supported and the value cannot contain the country code.
Condition Branch Description
Table 1 Condition branch description
Condition Branch
Usage
SYSERROR_INNER
ODFS internal error
Triggered when an unknown error occurs in the ODFS. If no option is selected, the flow goes to the exception handling flow.
Typical Application Scenario
When a user calls the CEC and the call is routed to the IVR, if the IVR is configured with a Short Message diagram element, the Short Message diagram element is used to send an SMS message to the user.
The configuration method is as follows:
  • Application Scenario
  1. Choose Configuration Center > Flow Configuration > Flow Management, click New, set the flow name and type, and set Is Referenced to Yes.
    Figure 5 Adding a flow
  2. Click Edit to develop the flow as follows.
  3. Click or drag the Short Message diagram element in the Feature area on the left. The Short Message diagram element is added to the canvas.
  4. Set parameters of the Short Message diagram element and click Save. (Huawei Cloud SMS is used as an example.)
    Figure 6 Short Message
    Figure 7 Satisfaction Survey
  5. Add connection lines. If there are no other diagram elements, the flow is shown in the following figure.
    Figure 8 Example
  6. Perform subsequent operations based on business requirements. You can add other diagram elements. After the configuration is complete, click to save the flow.
