Updated on 2025-11-07 GMT+08:00
Time Selection
The orchestration capability varies depending on the time. That is, the holiday time of each region may be different. During flow orchestration, perform different orchestration operations based on the holidays and working days.
Diagram Element
Parameter Description
  • Node Name: name of a node.
  • Description: details of a node.
  • Week Selection: Select the working days of a week.
  • Service Period: Select the start working time and end working time.
  • Specified Service Date: Specify one or more dates as working dates.
  • Specified Non-service Date: Specify one or more dates as non-working dates.
The time zone is that set by the system administrator when the tenant space is created. If the time zone is not set when the tenant space is created, the value of the built-in variable timezone is used.
The configuration priority is as follows: Specified Non-service Date > Specified Service Date > Week Selection.
Condition Branch Description
Table 1 Condition branch description
Condition Branch
Usage
NON_SPECIFIC_TIME
Non-working time
Triggered when the current time is non-working time.
SYSERROR_INNER
ODFS internal error
Triggered when an unknown error occurs in the ODFS. If no option is selected, the flow goes to the exception handling flow.
Using the Diagram Element
The holiday time of each region may be different. During flow orchestration, perform different orchestration operations based on the holidays and workdays.
Click the diagram element or drag it to the canvas, and set parameters based on the parameter description.
Typical Application Scenario
The following describes how to use the Time Selection diagram element to determine whether the current time is working time for subsequent business handling.
  1. Sign in to the AICC and choose Configuration Center > Chatbot Management > Flow Configuration.
  2. Configure an intelligent robot.
    1. Choose Flow > Orchestration and click Create to add a simple flow.
      Figure 1 Flow orchestration example (Time Selection diagram element)
    2. Save and publish the flow.
  3. Choose Intelligent Chatbot and bind the flow to a robot.
  4. Choose Intelligent Chatbot. In the last column corresponding to the robot, click Test Call.
    In the test dialog box that is displayed, click Start Call to test the robot. If the robot replies based on whether the current time is working time, the configuration is successful.
    Figure 2 Test Call page
