Help Center/
Customer Engagement Center/
User Guide/
Tenant Administrator Guide/
Performance Management/
Performance Configuration/
Performance Plan
Updated on 2025-01-23 GMT+08:00
Performance Plan
- The performance management feature has been enabled for the tenant space.
- Sign in to the AICC as the system administrator.
- Choose Call Center > Tenant Management.
- Click Edit in the row containing the current tenant.
- Click the Virtual Call Center tab. In the Feature Selection area, enable the Performance Management feature.
Figure 1 Enabling the performance management feature
The performance management feature depends on the AppCube feature. Before enabling the performance management feature, enable the AppCube feature.
- The performance algorithm has been configured.
- Sign in to the AICC as a tenant administrator, choose Configuration Center > Performance management > Performance configuration, and choose Performance Plan.
Figure 2 Performance plan page
- Click Create and create a performance plan. Configure Program Information first.
Figure 3 Creating a performance plan - Program Information page
- Performance PlanName: Customize a value with a maximum of 100 characters.
- Assessment Cycle Type: Select an appraisal period type.
- Monthly
- Quarter
- Semiannual
- Year
- Customize: If you select Customize, the time span cannot exceed 366 days but can cross years.
- Assessment Cycle: Select an appraisal period based on the appraisal period type.
- Assessment Data Period: Set a specific appraisal time period.
- Performance Algorithm: Select an existing performance algorithm. If no algorithm is available, click
to create an algorithm for the current performance plan.
- Click Next step, select applicable members for the performance plan.
Figure 4 Creating a performance plan - Applicable Members page
- After all the preceding information is configured, click Confirm.
- In the Operation column, click Edit or Delete for the current performance plan as required. A performance period that has been carried forward (that is, the appraisal is completed) cannot be edited.
Parent topic: Performance Configuration
