Configuring AICC Information
Updated on 2025-01-23 GMT+08:00
  • The system administrator has uploaded the Facebook authentication certificate on the Configuration Center > System Management > Certificate page.
  • You have obtained developer information from Meta for Developers.
    Visit Meta for Developers at https://developers.facebook.com/ to apply for a developer account. View the account information on the page shown in the following figure.
Context
  • Facebook allows an application to connect to multiple systems, but the AICC requires that one Facebook application connect to one channel to prevent duplicate messages.
  • If the app secret and token secret provided by Facebook are changed on Facebook, you need to modify the involved Facebook channel as follows: Sign in as a tenant administrator, choose Configuration Center > Access Configuration > Channel Configuration, click Edit in the Operation column corresponding to the involved channel, and update the value of App Secret. After saving the channel configuration, click Configuration in the Operation column corresponding to the involved channel, and update the value of Token Secret.
  1. Sign in to the AICC as a tenant administrator and choose Configuration Center > Access Configuration > Channel Configuration.
  2. Click Newly created. The Configure Channel page is displayed.
  3. Set channel information parameters.
    Table 1 Channel information parameters
    Channel Selection
    Select Facebook.
    App Secret
    App secret on Meta for Developers.
    Interconnection Encryption Algorithm
    Encryption algorithm used for Facebook interconnection. The options are as follows:
    • SHA-1
    • SHA-256
    SHA-1 is not strong enough, which poses security risks. If the platform supports SHA-256, you are advised to use this algorithm, which is stronger.
  4. Set basic configuration parameters.
    Table 2 Basic configuration parameters
    Channel Name
    The channel name must be unique. The code can contain a maximum of 64 characters, including only letters, digits, and underscores (_), and can start only with a letter or an underscore (_).
    OU Configuration
    Select an OU created in Configuring OUs to assign it to channel resources.
    Skill Queue
    The options are all multimedia called routes of the current tenant space. For details about how to configure a called route, see Configuring Called Routes.
    Keyword for Transfer to Agent
    Keywords for switching from robot service to manual service. After a customer enters any of the keywords on the client, robot service is switched to manual service.
    If the intelligent robot is enabled, this parameter must be set.
    Agent Work Time
    • Workday: A maximum of four working time segments (from 00:00 to 24:00) can be configured. By default, a time segment is displayed. You can click New to add a time segment.
    • Non-workday: A maximum of four working time segments (from 00:00 to 24:00) can be configured. By default, a time segment is displayed. You can click New to add a time segment.
      Non-working days are set on the Configuration Center > Workbench Configuration > Service Time page.
    Non-Working Time Notification
    When a customer call is connected to an agent in non-working time, this message is displayed to notify the customer that the agent is in rest state.
    More
    Last Agent Mode
    For details, see How Do I Enable the Last Agent Mode?.
    Session End Due to No Customer Reply
    For details, see How Do I Set Session End Due to No Customer Reply?.
    Session Transfer Due to No Agent Reply
    For details, see How Do I Set Session Transfer Due to No Agent Reply?.
    Session Transfer
    For details, see How Do I Set Session Transfer?.
  5. Set robot configuration parameters.
    Table 3 Robot configuration parameters
    Connecting to the Intelligent Robot
    For details, see How Do I Enable Connection to the Intelligent Robot?.
    Access Robot Assistant
    For details, see How Do I Enable Connection to the Robot Assistant?.
  6. Click The next step and go to Meta for Developers to configure the URL and verification code.
  7. Visit the URL and click Submit to perform token authentication. If the token passes the authentication, the access is successful. Return to the AICC and click Submit. The Successful access page is displayed.
Follow-up Procedure
  • The Facebook channel supports multiple Facebook home pages, and each Facebook home page can be configured only for one Facebook channel.
    1. Click Create to configure multiple home pages for the Facebook channel so that multiple Facebook home pages can be connected to agents.
      1. Page ID: home page ID on Meta for Developers
      2. TokenSecret: token secret on Meta for Developers
    2. Click Save.
  • Export channel information.
    • All information under Basic Configuration and Robot Configuration can be exported. Passwords and keys cannot be exported.
    • A maximum of 100,000 channel records can be exported at a time, and a maximum of 2000 records are allowed in an exported file.
    • If no channel is selected, all channel information is exported by default.
    1. Return to the channel list.
    2. Select the new channel and click to export the channel information.
    3. Click and confirm that Status of the export task is Success.
    4. Click Download to obtain the exported channel information.
