Configuring an HTTPS Certificate
Background
CDN supports HTTPS acceleration. You can configure an HTTPS certificate for an acceleration domain name on the CDN console. Then clients can use HTTPS to access CDN PoPs. The differences between HTTP and HTTPS are as follows:
- HTTP
HTTP transfers content in plaintext without any data encryption. If an attacker intercepts packets transmitted between browsers and website servers, the transmitted content can be read directly.
- HTTPS
Based on HTTP, HTTPS uses Secure Sockets Layer (SSL) to encrypt data transmission. With SSL, servers are authenticated using certificates, and communications between browsers and servers are encrypted.
- CDN supports your own certificates or SSL Certificate Manager (SCM) certificates. The format of your own certificates must meet the requirements described in HTTPS Certificate Requirements.
- Only certificates and private keys in PEM format are supported. If a certificate is not in PEM format, convert the certificate by referring to HTTPS Certificate Requirements.
- If two certificates are set for a domain name, the certificate standards must be different. That is, if you have added an international certificate for a domain name, you can only add a Chinese (SM2) certificate.
- To change the certificate type from International to Chinese (SM2), QUIC should be disabled first.
Precautions
- An acceleration domain name has its associated certificate. They must match. If your domain name is a wildcard domain, configure a certificate for it by referring to How Do I Configure a Certificate If My Domain Name Is a Wildcard Domain?
- Certificate settings will be automatically deleted once HTTPS acceleration is disabled. To enable HTTPS acceleration again, you need to re-configure the certificate.
- If your certificate has changed, update certificate information on the CDN console in a timely manner.
- For details about how to update your own certificate, see Updating an HTTPS Certificate.
- For details about how to use the latest SCM certificate, see Configuring an HTTPS Certificate.
- To use HTTPS for all links, the origin protocol should be HTTPS (and the origin server must support HTTPS). For details, see Origin Protocol.
- When HTTPS is disabled, all HTTPS requests from clients cannot complete SSL handshakes and will fail.
- Log in to the CDN console.
- In the navigation pane, choose .
- In the domain list, click the target domain name or click Configure in the Operation column.
- Click the HTTPS Settings tab.
- On the HTTPS Settings tab page, click Edit.
Figure 1 Configuring an HTTPS certificate
- Switch on Status to enable this configuration item.
- Set related parameters.
Table 1 Parameters of an international certificate Parameter
Certificate Standard
International: SSL certificate that complies with international standards.
Certificate Source
Either My certificate or SCM certificate
Certificate Name
- My certificate: Enter the certificate name containing 3 to 64 characters.
- SCM certificate: CDN automatically obtains SSL certificates uploaded to the CCM console. You only need to select the desired one from the drop-down list.
Certificate Body
- My certificate: Use a local text editor to open the certificate and copy the content to the text box.
- SCM certificate: The certificate body is automatically filled in.
NOTE:- The certificate body cannot contain spaces or blank lines. Otherwise, a message is displayed indicating that certificate parameters are incorrect.
- The size of the certificate body cannot exceed 20 KB.
Private Key
- My certificate: Use a local text editor to open the private key and copy the content to the text box.
- SCM certificate: The private key is automatically filled in.
- The size of the private key cannot exceed 20 KB.
Table 2 Parameters of a Chinese SM series cryptographic certificate Parameter
Chinese (SM2)
Certificate Source
Select My certificate or SCM certificate.
Certificate Name
Signature Certificate
Open the PEM file in the signature certificate to be uploaded as a text file and copy the certificate content in the file to this text box.
Note that you need to upload a combined certificate file that contains both the server certificate content and certificate chain content into this field. The content of the certificate chain should be pasted right below the content of the server certificate.
- The size of the signature certificate cannot exceed 20 KB.
Signature Private Key
Open the KEY file in the signature certificate to be uploaded as a text file and copy the private key in the file to this text box.
- The size of the signature private key cannot exceed 20 KB.
Encryption Certificate
Open the PEM file in the encryption certificate to be uploaded as a text file and copy the certificate content in the file to this text box.
You do not need to upload the certificate chain here.
- The size of the encryption certificate cannot exceed 20 KB.
Encryption Private Key
Open the KEY file in the encryption certificate to be uploaded as a text file and copy the private key in the file to this text box.
- The size of the encryption private key cannot exceed 20 KB.
- (Optional) To set another certificate, click Add at the bottom and set related parameters.
Standards of the two certificates must be different. For example, if you have set an international certificate, you can add a Chinese (SM2) certificate.
- Click OK.
Checking Whether a Certificate Has Taken Effect
A certificate works across the entire network about 5 minutes after it is configured. Then you can access resources of the acceleration domain name via HTTPS and check the website authentication information by clicking in the address box of the browser.
If your domain name certificate is updated, you need to update the certificate details in the HTTPS configuration item.
- Log in to Huawei Cloud console. Choose .
The CDN console is displayed.
- On the HTTPS Settings tab, click Edit. The Configure HTTPS Secure Acceleration dialog box is displayed.
Figure 2 Updating a certificate
- Click Update to update the configured certificate and private key. It takes approximately 5 to 10 minutes for the update to take effect.
Viewing HTTPS Certificate Information
On the HTTPS certificate configuration page, you can view details about the HTTPS certificate configured for the acceleration domain names.
- On the page displayed, you can view details about the HTTPS certificate configured for the domain name, such as the certificate expiration time. You can also view the certificate content. However, the private key content cannot be viewed, for security reasons.
Disabling a Certificate
Click Edit next to HTTPS Settings.
- Disable the Status switch and click OK.
- Disable QUIC before disabling the certificate.
Certificate Expiration Time
The expiration time of a certificate chain is the same as that of the certificate that first expires in the chain.
Huawei Cloud CDN sends an SMS or email notification to the mobile number or email address bound to your account 30 days, 15 days, and seven days before the certificate expires. However, no notification is sent when the domain name is in the disabled, banned, deleting, or reviewing state. For details about how to change the mobile number and email address, see Binding or Changing the Service Mobile Number and Changing the Service Email Address. To view the mobile number and email address of the recipient, see What Are the Parameters and How Can I Use Them in the Account Center?
