Updated on 2026-11-18 GMT+08:00
Overview
CDN caches origin content on PoPs across the globe so that users can obtain content from nearby PoPs. You can modify rules and relevant settings of caches on CDN PoPs.
You can modify cache settings of a domain name that is in the Enabled or Configuring state and is not locked or banned.
Function
CDN PoP Cache Rules
Set the cache TTL and priority for different resources to increase the hit ratio and reduce the back-to-source rate.
Browser Cache TTL
Set a browser cache TTL, during which users can obtain content directly from their browser cache (if available), reducing origin pulls.
Cache TTL of Origin Response Status Codes on CDN PoPs
Cache error status codes returned by the origin server to CDN PoPs for a specified TTL. CDN returns the error codes to users when they request resources within this TTL, reducing the origin pull ratio and origin server pressure.
Client Access URL Rewrite
Set access URL rewrite rules to redirect user requests to the URLs of cached content.
Shared Cache Groups
Configure a shared cache group with a primary domain name to share its cache with other domain names. This improves the cache hit ratio when these domain names host the same resources.
If you have modified the cache rules and origin cache control settings,
  • Your modifications are effective for newly cached content.
  • You can purge to apply modifications to the existing cache.
