Overview
When a user requests content on an acceleration domain name, and the content is not cached on CDN PoPs, CDN PoPs will pull the content from the origin server. You can set origin parameters based on your needs to speed up access.
CDN Origin Pull Principle
- An end user initiates a request when visiting a website. DNS resolution points the URL requested by the client (such as a browser) to the acceleration domain name.
- The CDN PoP searches the cache. If the resource has been cached on the CDN PoP, the PoP returns the resource to the client.
- The CDN PoP initiates a pull request to the origin server based on the origin pull policy of the domain name if the requested resource is not cached on the PoP.
- The origin server returns the requested resource to the PoP based on the requested URL and parameters.
- The PoP returns the resource to the client. It also caches the resource for future requests from clients.
Supported Configuration Items
You can modify origin settings of a domain name that is in the Enabled or Configuring state and is not locked or banned.
| Function | Description |
| If the IP address or domain name of the origin server changes or origin server information is incorrect, modify the origin server settings. | |
| If the domain name you want CDN to pull content is not your acceleration domain name, set a host header. CDN regards an acceleration domain name as the host by default. | |
| Configure the request protocol used by CDN for origin pull. | |
| If your origin server IP address is bound to multiple domains and CDN visits the origin server using HTTPS, set the SNI to specify the domain to be visited by CDN during origin pull. | |
| If the URLs of origin pull requests do not match the origin server URLs, rewrite the request URLs to improve the origin pull hit ratio. | |
| Configure advanced origins to allow CDN to pull content of different resource types or paths from different origin servers. | |
| Allow CDN to pull large files from the origin server by range and return ranges to users, speeding up distribution and reducing bandwidth consumption. | |
| If your origin server uses a 301/302 redirect, enable redirect from origin to cache the redirected resources on CDN PoPs for accelerated distribution. | |
| Enable entity tag (ETag) validation, so that when cached resources on PoPs expire, CDN can check whether the resources are updated on the origin server based on the ETag value during origin pull. | |
| Adjust the origin response timeout based on the features and service scenarios of your origin server. | |
| Add or delete specified headers in users' request URLs for origin pull. | |
| By default, CDN pulls dynamic content from the origin server with the best performance. Choose to pull content from origin servers based on their weights. |
