Updated on 2026-09-21 GMT+08:00
Notebook
Data exploration and algorithm prototyping are the most time-consuming and iterative stages in the full AI model development lifecycle. Traditional local development models face three major challenges:
  • Computing bottleneck: Local notebooks or workstations struggle to manage the high-concurrency computing demands of large model fine-tuning and extensive data preprocessing, resulting in prolonged iteration cycles.
  • Environment dependency dilemma: Deep learning frameworks (PyTorch and MindSpore), underlying drivers (CUDA and CANN), and Python library versions are tightly coupled, making it extremely challenging to maintain consistent environments across teams.
  • Data transfer costs: Enterprise training datasets often reach TB or even PB scale, typically stored in cloud object storage (OBS) or file storage (SFS). Transferring this data to local environments is time-consuming and increases data leakage risk.
To overcome these bottlenecks, cloud-native IDEs based on JupyterLab and VS Code Server have become industry standards. The Notebook add-on shifts workloads from local development environments to underlying CCE clusters, giving developers browser-based access to an interactive R&D workspace with top-tier GPU/NPU compute, high-performance shared storage, and out-of-the-box runtime environments.
Open source address: Notebook Controller
Fundamental Concepts
Understanding the following core cloud-native concepts before using this add-on will help you manage your development environment more effectively:
  • Notebook Custom Resource Definition (CRD): the core abstraction introduced by this add-on. The YAML file with kind: Notebook is a declarative configuration. You simply specify your requirements, and the controller automatically manages all underlying details, such as creating pods, mounting volumes, and configuring networks.
  • PersistentVolumeClaim (PVC): In cloud-native environments, containers are ephemeral by design. Data in a pod is lost on pod restart. A PVC functions like a cloud USB drive mounted to a pod. It persistently stores your code, Conda environments, and personal configuration files, decoupling storage from compute.
  • StatefulSet: the underlying workload controller that manages notebook pods. Unlike Deployments, StatefulSets maintain stable network identities and ensure your PVC is accurately remounted after rescheduling (for example, during a node failover).
  • Resource culling: a cost-optimization mechanism. The controller monitors environment activity (such as Jupyter kernel or terminal connection statuses). When an environment has been idle for an extended period, the controller automatically hibernates it by scaling pods to zero, releasing compute resources back to the cluster while preserving all persistent data.
  • A CCE standard or Turbo cluster v1.29 or later is available. For details, see Buying a Standard/Turbo Cluster.
  • Target service nodes and add-ons are provisioned with adequate resources.
    • NPU services: NPU nodes are created with CCE AI Suite (Ascend NPU) installed.
    • GPU services: GPU nodes are created with CCE AI Suite (NVIDIA GPU) installed.
Precautions
Uninstalling Notebook does not automatically delete its CRDs or CRs. Delete them manually to complete cleanup.
Notes and Constraints
  • This add-on only deploys the notebook-controller for Notebook pods and manages their configurations. Notebook images must be custom-built or sourced from the community.
  • This add-on is in initial rollout. Check the console for supported regions.
  • This add-on is in OBT. You can access the latest features, but stability is not fully verified and no CCE SLA applies.
Billing
To access Notebook pods, bind an EIP to any cluster node. EIP usage is billed. For details, see EIP Price Calculator.
Installing the Add-on
  2. In the navigation pane, choose Add-ons. Locate Notebook on the right and click Install.
  3. In the Install Add-on sliding window, configure the specifications.
    Example Value
    Pods
    At least one notebook-controller pod will be created when this add-on is installed.
    CPU Quota
    Request: 100m
    The minimum CPU request per container.
    Limit: 500m
    The maximum CPU available to each container. If the CPU usage exceeds this limit, the pod may be restarted, affecting add-on availability.
    Memory Quota
    Request: 100 MiB
    The minimum memory request per container.
    Limit: 500 MiB
    The maximum memory available to each container. If the memory usage exceeds this limit, the pod may be restarted, affecting add-on availability.
  4. In the Parameters area, properly configure the parameters below based on applications.
    Example Value
    clusterDomain
    cluster.local
    The DNS domain suffix for internal Kubernetes cluster services. The controller uses it to generate fully-qualified domain names (FQDNs) for Notebook Services, for example, notebook-name.namespace.svc.cluster.local.
    This parameter defaults to cluster.local. If you customized the internal domain name during CCE cluster creation, update this parameter accordingly. A mismatch will cause Service communication failures.
    enableCulling
    false
    Whether to enable automatic reclamation of idle Notebook pods.
    • true: enabled. The controller periodically identifies inactive Notebook pods and scales them in to zero, freeing underlying compute resources. Data on attached disks is preserved.
    • false: disabled. Once started, pods continue running until manually deleted or scaled to zero.
      Enable this function (true) in production environments with high-cost compute resources such as GPUs or NPUs to significantly reduce idle resource expenditure.
    cullIdleTime
    1440
    The idle timeout (in minutes) before automatic reclamation of Notebook pods. This specifies the maximum duration a Notebook pod can remain active without any activity, such as no active connections or code execution.
    The example value 1440 represents 24 hours. If a Notebook pod is idle for 24 consecutive hours, CCE automatically suspends it. You can reduce this duration based on your organization's resource needs, for example, set it to 120 (2 hours) or 240 (4 hours).
    CAUTION:
    This parameter applies only when enableCulling is set to true.
    idlenessCheckPeriod
    The polling interval (in minutes) for detecting idle status. This specifies how often the controller sends a detection request to a Notebook pod's active status API to monitor HTTP traffic and Jupyter kernel status.
    The example value 1 indicates that the idle time is detected and calculated every minute.
    Retain the default setting in most cases. If your cluster is large (thousands of pods), you can increase this value, for example, set it to 5, to reduce query pressure on the Kubernetes API server and controller.
  5. Click Install.
Components
Table 1 Notebook components
Component
Resource Type
notebook-controller
Manages Notebook pod lifecycle.
Deployment
Notebook CR Settings
The Notebook CRD acts as a lightweight controller shell. It maps the spec.template.spec field to a complete, native Kubernetes PodSpec. Consequently, Notebook pods natively support all advanced capabilities provided by the underlying Kubernetes system.
  • Common Notebook CR settings
    apiVersion: kubeflow.org/v1
    kind: Notebook
      namespace: team-algorithm
      labels:
        project: llm-pretraining
      annotations:
        # [Dedicated configuration] Allow the frontend dashboard to display custom descriptions.
        notebooks.kubeflow.org/title: "LLM Core Development Environment"
        # [Advanced scheduling] Use Volcano Scheduler for optimized NPU/GPU topology.
        volcano.sh/scheduler-name: volcano
      template:
          # [Security policy] Specify that all processes within the container run as a non-root user by default (UID 1000, typically jovyan).
          securityContext:
            runAsUser: 1000
            fsGroup: 100
          # [Node scheduling] Schedule pods only to heterogeneous compute node pools with specific labels.
          nodeSelector:
            node.kubernetes.io/instance-type: "accelerated-compute-pool"
          # [Taint tolerance] Tolerate taints on AI-dedicated nodes to prevent general service pods from preempting AI workload resources.
          tolerations:
          - key: "nvidia.com/gpu"
            operator: "Exists"
            effect: "NoSchedule"
          containers:
          - name: notebook
            image: custom-registry.io/jupyter-ai-base:v2.0
            imagePullPolicy: Always
            # [Environment variables] Inject general environment configurations or service parameters.
            env:
            - name: JUPYTER_ENABLE_LAB
              value: "yes"
            - name: MODEL_CACHE_DIR
              value: "/data/models"
            # [Resource declaration] Declare core compute resource configurations.
            resources:
              requests:
                cpu: "8"
                memory: "32Gi"
              limits:
                cpu: "8"
                memory: "32Gi"
                # [Heterogeneous computing] Use accelerator cards exclusively. Specify GPU or NPU identifiers as needed.
                nvidia.com/gpu: 1
                # huawei.com/Ascend910: 1
            volumeMounts:
            - mountPath: /home/jovyan/work       # Personal workspace (read/write)
            - mountPath: /data/public-datasets   # Public datasets (read-only)
            - mountPath: /dev/shm                # Shared memory optimization for multi-process data loading bottlenecks
          volumes:
          # 1. Mount a persistent cloud disk for code storage.
          - name: workspace-pvc
            persistentVolumeClaim:
              claimName: workspace-claim-user01
          # 2. Mount a high-performance file system (for example, SFS Turbo) for large datasets.
          - name: dataset-pvc
              claimName: public-datasets-claim
          # 3. Mount a memory file system to accelerate multi-process reads (for example, PyTorch DataLoader).
          - name: dshm
            emptyDir:
              medium: Memory
              sizeLimit: "8Gi"
  • Suggestions for production environments
    • Stateless images with stateful storage
      Do not install time-consuming underlying dependencies (such as a specific CUDA/CANN version or C++ libraries requiring large-scale compilation) directly in a Notebook instance using pip install or apt-get. These installations are ephemeral and will be lost when the instance is reclaimed or restarted, making environments non-reproducible and forcing repeated rebuilds. Recommended approach:
      • Build Docker base images containing the underlying drivers and deep learning frameworks (such as PyTorch or MindSpore) to standardize and reuse environments.
      • Mount persistent storage to /home/jovyan/work and use venv or Conda for persistent installation and version management of lightweight Python dependencies (such as the requests library).
    • Unified network and route naming
      When a large number of Notebook instances are created concurrently, a large number of Services with identical names are generated in the cluster, causing network conflicts, resource contention, and management difficulties. To prevent these issues, follow these rules:
      • Each service team must have an independent Kubernetes namespace to isolate environments.
      • Notebook names must follow the format [Username]-[Project abbreviation]-[Date] to facilitate billing audits and batch identification and cleanup of orphaned instances.
Use Cases
This example demonstrates how to run CUDA code on a GPU-enabled Notebook instance (using a P4 GPU). Ensure the cluster contains GPU nodes and has the GPU and Notebook add-ons installed.
  1. Create a Notebook instance.
    1. Install kubectl on an existing ECS and use kubectl to access the target cluster. For details, see Accessing a Cluster Using kubectl.
    2. Create a YAML file for pods configured with virtual GPU burst scheduling.
      vim notebook-sample.yaml
      The file content is as follows:
      kind: Notebook
        name: notebook-sample-v1    # Name of the Notebook instance
        template:
            containers:
              - name: notebook-sample-v1     # Name of the container
                image: quay.io/jupyter/pytorch-notebook:cuda13-latest  # Path to the used Notebook image
                resources:
                  limits:
                    cpu: 250m
                    memory: 512Mi
                    nvidia.com/gpu: '1'
                  requests:
                    cpu: 250m
                    memory: 512Mi
                    nvidia.com/gpu: '1'
      In this example, the image quay.io/jupyter/pytorch-notebook:cuda13-latest is hosted in an external Docker registry. Ensure your CCE nodes can access this registry. If your nodes cannot reach the registry, pull the image and upload it to Huawei Cloud SWR beforehand.
    3. Create the Notebook instance.
      kubectl apply -f notebook-sample.yaml
      If information similar to the following is displayed, the Notebook has been created:
      notebook.kubeflow.org/notebook-sample-v1 created
    4. Check the Notebook CR status.
      kubectl get Notebook
      Information similar to the following is displayed:
      NAME                 AGE
      notebook-sample-v1   25h
      If your Notebook name (for example, notebook-sample-v1) is displayed in the list, the CR has been created.
    5. View the created pod.
      kubectl get pod |grep notebook-sample-v1
      notebook-sample-v1-0             1/1     Running   0               28m
      If the command output contains Running, the instance is running.
  2. Access the Notebook.
    1. View the label of the Notebook pod.
      kubectl describe pod notebook-sample-v1-0
      Key output:
      Labels:           apps.kubernetes.io/pod-index=0
                        controller-revision-hash=notebook-sample-v1-6bb8bb48ff
                        notebook-name=notebook-sample-v1
                        statefulset=notebook-sample-v1
                        statefulset.kubernetes.io/pod-name=notebook-sample-v1-0
      Use statefulset=notebook-sample-v1 as the label, as it is a native, stable, and predictable Kubernetes management label.
    2. Create a Service.
      1. Create notebook-service.yaml (filename customizable) to configure a NodePort Service. This Service exposes the Notebook so it can be accessed directly from a browser.
        vim notebook-service.yaml
        File content:
        apiVersion: v1
        kind: Service
          namespace: default
          externalTrafficPolicy: Cluster
          internalTrafficPolicy: Cluster
          ports:
          - name: http-notebook-sample-v1
            port: 80                # Port exposed by the Service
            protocol: TCP
            targetPort: 8888  # Port on the target container. This corresponds to the application port (typically 8888 for Jupyter Notebook).
          selector:
            statefulset: notebook-sample-v1
          sessionAffinity: None
          type: NodePort  # Service type. NodePort exposes the Service on each node's IP at a fixed port.
      2. Create the Service.
        kubectl create -f notebook-service.yaml
        If the command output contains created, the Service has been created.
      3. Check the Service NodePort.
        kubectl get services
        In the command output shown below, 32666 is the assigned NodePort.
        NAME                 TYPE        CLUSTER-IP       EXTERNAL-IP   PORT(S)        AGE
        notebook-sample-v1   NodePort    10.247.**.**     <none>        80:32666/TCP   24h
    3. Obtain a token.
      1. Enter the Notebook container.
        kubectl exec -it notebook-sample-v1-0 -- bash
      2. Obtain the token.
        jupyter server list
        Command output:
        Currently running servers:
        http://localhost:8888/?token=ab23a4dfd63b... :: /home/jovyan
    4. Access the Jupyter UI. In the browser address bar, enter http://<EIP_of_any_node>:32666 to open the Notebook.
      Ensure an EIP is bound to a cluster node. Log in to the CCE console, click the cluster name to access the cluster console, choose Nodes in the navigation pane, click the Nodes tab in the right pane, and click the node name to go to the ECS console. Then, bind an EIP to the target ECS. For details, see Binding an EIP.
    5. On the login page, enter the obtained token and click Log in.
  3. Test connectivity.
    1. On the Jupyter page, click Python 3.
    2. Run the following script:
      import torch
      # 1. Check if GPU is available
      print("1. Is GPU available:", torch.cuda.is_available())
      if torch.cuda.is_available():
          # 2. Try creating a simple Tensor in GPU memory
          x = torch.tensor([1.0, 2.0], device='cuda')
          print("2. Tensor located on device:", x.device)
      else:
          print("No GPU detected, please check your environment configuration.")
      Is GPU available: True
      Tensor located on device: cuda:0
  • How to Obtain and Select a Proper Notebook Image?
    A container image determines the software, frameworks, and underlying drivers pre-installed in the development environment. To ensure successful startup, the image must comply with basic containerized interface standards. The following describes common methods for obtaining high-quality images:
    • Kubeflow official community images (general-purpose CPU/GPU)
      The Kubeflow community maintains a series of rigorously tested base images covering the most commonly used data science stacks. You can pull these directly from the public image repository:
      • Basic data science (including Pandas and Scikit-learn): kubeflow/jupyter-scipy:latest
      • Official PyTorch integration: kubeflow/jupyter-pytorch:latest
      • Official TensorFlow integration: kubeflow/jupyter-tensorflow:latest
        How to obtain: Search for the image with a specific tag on Docker Hub (hub.docker.com/u/kubeflow).
    • Jupyter Docker Stacks (upstream open-source images)
      • Versatile data science stack: jupyter/datascience-notebook
        How to obtain: Visit Selecting an Image in the Jupyter official documentation, or search Docker Hub under the jupyter namespace.
Release History
Table 2 Notebook updates
Add-on Version
Supported Cluster Version
New Feature
1.10.1
  • v1.29
  • v1.30
  • v1.31
  • v1.32
  • v1.33
  • v1.34
  • v1.35
The Notebook plugin is now available.
