Enabling Observability for cilium-agent in a Cluster with DataPlane V2 Enabled
In a cluster with DataPlane V2 enabled, the cilium-agent component is deployed on each node. You can enable the observability for this component by referring to this section.
- CCE DataPlane V2 is released with restrictions. To use this feature, submit a service ticket to CCE.
- Currently, only CCE standard clusters of v1.27.16-r50, v1.28.15-r40, v1.29.15-r0, v1.30.14-r0, v1.31.10-r0, v1.32.6-r0, and later versions that have DataPlane V2 enabled support the observability of the cilium-agent component.
Step 1: Configure a ConfigMap and Rebuild yangtse-cilium
- Connect to your cluster using kubectl. For details, see Accessing a Cluster Using kubectl.
- Create the cilium-config.yaml file and specify the following native ConfigMap configuration of the Cilium community:
apiVersion: v1 data: prometheus-serve-addr: :9962 kind: ConfigMap metadata: name: cilium-config namespace: kube-system
Table 1 Parameters Parameter
Remarks
Address for accessing the metrics of the cilium-agent component.
This parameter is set to :9962 here. The colon cannot be omitted.
- Create the ConfigMap.
kubectl apply -f cilium-config.yaml
- Roll back and rebuild yangtse-cilium to apply the configuration.
uuid=$(uuidgen) kubectl patch daemonset -nkube-system yangtse-cilium --type='json' -p="[{\"op\": \"add\", \"path\": \"/spec/template/metadata/annotations/change-id\", \"value\": \"$uuid\"}]"
Step 2: Install Add-ons
- Install the Cloud Native Cluster Monitoring add-on. For details, see Cloud Native Cluster Monitoring.
- Install the Grafana add-on. For details, see Grafana.
Step 3: Configure a Cilium Observability Task
- Create the cilium-monitor.yaml file. You can specify the following configuration to create a ServiceMonitor for Cilium observability.
apiVersion: v1 kind: Service metadata: annotations: prometheus.io/port: "9962" prometheus.io/scrape: "true" labels: k8s-app: cilium name: cilium namespace: kube-system spec: clusterIP: None clusterIPs: - None internalTrafficPolicy: Cluster ipFamilies: - IPv4 ipFamilyPolicy: SingleStack ports: - name: metrics port: 9962 protocol: TCP targetPort: prometheus selector: k8s-app: cilium sessionAffinity: None type: ClusterIP --- apiVersion: monitoring.coreos.com/v1 kind: ServiceMonitor metadata: name: cilium namespace: monitoring spec: endpoints: - honorLabels: true path: /metrics port: metrics relabelings: - action: labelmap regex: __meta_kubernetes_service_label_(.+) scheme: http jobLabel: cilium namespaceSelector: matchNames: - kube-system selector: matchLabels: k8s-app: cilium - Create the ServiceMonitor.
kubectl apply -f cilium-monitor.yaml
Step 4: Configure the Cilium Metric Dashboard
The Cilium official website provides a Grafana dashboard for Cilium metrics. Compared with the monotonous metrics of Prometheus, the Grafana dashboard is more attractive. You can access the dashboard to view Cilium metrics.
- Prepare the configuration file of the Cilium metric dashboard. Open the Prometheus sample file in the Cilium community, locate cilium-dashboard.json in the file, and copy it.
- Log in to Grafana, choose Dashboards, and import the cilium-dashboard.json file.
If you have enabled Interconnect with AOM when installing the Grafana add-on in Step 2: Install Add-ons, change the datasource field in the cilium-dashboard.json file to prometheus-aom, and then import the file.
- Access the dashboard to view Cilium metrics. For details about Cilium metrics, see cilium-metrics.
