Help Center/ Cloud Container Engine/ User Guide/ Networking/ Container Networks/ Pod Network Settings/ Deploying Hubble for DataPlane V2 Network Observability
Updated on 2026-08-13 GMT+08:00
In a cluster with DataPlane V2 enabled, you can deploy Hubble, an open-source observability project, for the visual display of container network traffic and container network observability.
  • Hubble can be deployed in CCE standard clusters v1.27.16-r50, v1.28.15-r40, v1.29.15-r0, v1.30.14-r0, v1.31.10-r0, v1.32.6-r0, or later when DataPlane V2 is enabled.
  • Hubble can be deployed in CCE Turbo clusters v1.34.3-r10 or later when DataPlane V2 is enabled.
Step 1: Configure a ConfigMap and Rebuild yangtse-cilium
  1. Connect to your cluster using kubectl. For details, see Accessing a Cluster Using kubectl.
  2. Specify the following native ConfigMap configuration of the Cilium community:
    apiVersion: v1
    kind: ConfigMap
      namespace: kube-system
    data:
      enable-hubble: "true"
      hubble-disable-tls: "true"
      hubble-listen-address: :4244
      hubble-metrics: dns drop tcp flow port-distribution icmp http
      hubble-metrics-server: :9965
    Table 1 Parameters
    Remarks
    enable-hubble
    Whether to enable Hubble. true indicates Hubble is enabled, and false indicates Hubble is disabled.
    This parameter is set to true here.
    hubble-disable-tls
    Whether to disable TLS on the Hubble server. true indicates TLS is disabled, and false indicates TLS is enabled.
    Listening address of the Hubble server.
    This parameter is set to :4244 here. The colon cannot be omitted.
    hubble-metrics
    Metrics to be collected by Hubble. Separate multiple metrics with spaces.
    The metrics that can be collected by Hubble include dns, drop, tcp, flow, flows-to-world, httpV2, icmp, kafka, and port-distribution. For details, see Metrics supported by the Cilium community.
    If you specify a large number of metrics, the Hubble performance will be affected.
    Address for accessing Hubble metrics.
    This parameter is set to :9965 here. The colon cannot be omitted.
  3. Roll back and rebuild yangtse-cilium to apply the configuration.
    kubectl rollout restart daemonset/yangtse-cilium -n kube-system
Step 2: Deploy Hubble Components
  1. Create the hubble.yaml file.
    The following is the file content:
    • Change the valid-cluster value in the configuration file to your current cluster name.
    • In the YAML example, the image tags for hubble-relay, hubble-ui, and hubble-ui-backend correspond to Cilium v1.19.4. Replace these tags with the community Hubble image tags matching your current Cilium version.
    apiVersion: v1
    automountServiceAccountToken: false
    kind: ServiceAccount
    apiVersion: v1
    kind: ClusterRoleBinding
    roleRef:
      apiGroup: rbac.authorization.k8s.io
      kind: ClusterRole
    subjects:
    - kind: ServiceAccount
    kind: ClusterRole
    rules:
    - apiGroups:
      - networking.k8s.io
      resources:
      - networkpolicies
      verbs:
      - get
      - list
      - watch
    - apiGroups:
      resources:
      - componentstatuses
      - endpoints
      - namespaces
      - nodes
      - pods
      - services
      verbs:
      - get
      - list
      - watch
    - apiGroups:
      - apiextensions.k8s.io
      resources:
      - customresourcedefinitions
      verbs:
      - get
      - list
      - watch
    - apiGroups:
      - cilium.io
      resources:
      verbs:
      - get
      - list
      - watch
    apiVersion: v1
    kind: Service
      labels:
        app: hubble-relay
      internalTrafficPolicy: Cluster
      ipFamilies:
      - IPv4
      ipFamilyPolicy: SingleStack
      ports:
      - port: 80
        protocol: TCP
        targetPort: grpc
      selector:
        app: hubble-relay
      sessionAffinity: None
      type: ClusterIP
    apiVersion: v1
    kind: Service
      annotations:
        prometheus.io/port: "9965"
        prometheus.io/scrape: "true"
      labels:
        app: hubble
      clusterIP: None
      clusterIPs:
      - None
      ipFamilies:
      - IPv4
      ports:
      - name: hubble-metrics
        port: 9965
        protocol: TCP
        targetPort: hubble-metrics
      selector:
        app: yangtse-cilium
      type: ClusterIP
    apiVersion: v1
    kind: Service
      labels:
        app: cilium
      internalTrafficPolicy: Local
      ipFamilies:
      - IPv4
      ports:
      - name: peer-service
        port: 80
        protocol: TCP
        targetPort: 4244
      selector:
        app: yangtse-cilium
      type: ClusterIP
    apiVersion: v1
    data:
      nginx.conf: "server {\n    listen       8081;\n    listen       [::]:8081;\n    server_name
        \ localhost;\n    root /app;\n    index index.html;\n    client_max_body_size
        1G;\n\n    location / {\n        proxy_set_header Host $host;\n        proxy_set_header
        X-Real-IP $remote_addr;\n\n        location /api {\n            proxy_http_version
        1.1;\n            proxy_pass_request_headers on;\n            proxy_pass http://127.0.0.1:8090;\n
        \       }\n        location / {\n            # double `/index.html` is required
        here \n            try_files $uri $uri/ /index.html /index.html;\n        }\n\n
        \       # Liveness probe\n        location /healthz {\n            access_log
        off;\n            add_header Content-Type text/plain;\n            return 200
        'ok';\n        }\n    }\n}"
    kind: ConfigMap
    apiVersion: v1
    data: # Change the valid-cluster value to your current cluster name.
      config.yaml: "cluster-name: valid-cluster\npeer-service: \"hubble-peer.kube-system.svc.cluster.local.:80\"\nlisten-address:
        :4245\ngops: true\ngops-port: \"9893\"\nretry-timeout: \nsort-buffer-len-max:
        \nsort-buffer-drain-timeout: \ndisable-client-tls: true\n\ndisable-server-tls:
        true\n"
    kind: ConfigMap
    apiVersion: apps/v1
    kind: Deployment
      labels:
        app: hubble-relay
      progressDeadlineSeconds: 600
      replicas: 1
      revisionHistoryLimit: 10
      selector:
        matchLabels:
          app: hubble-relay
      strategy:
        rollingUpdate:
          maxSurge: 25%
          maxUnavailable: 1
        type: RollingUpdate
      template:
          creationTimestamp: null
          labels:
            app: hubble-relay
          affinity:
            podAffinity:
              requiredDuringSchedulingIgnoredDuringExecution:
              - labelSelector:
                  matchLabels:
                    app: yangtse-cilium
                topologyKey: kubernetes.io/hostname
          containers:
          - args:
            - serve
            command:
            - hubble-relay
            image: quay.io/cilium/hubble-relay:v1.19.4
            imagePullPolicy: IfNotPresent
            livenessProbe:
              failureThreshold: 12
              grpc:
                port: 4222
                service: ""
              initialDelaySeconds: 10
              periodSeconds: 10
              successThreshold: 1
              timeoutSeconds: 10
            ports:
            - containerPort: 4245
              protocol: TCP
            readinessProbe:
              failureThreshold: 3
              grpc:
                port: 4222
                service: ""
              periodSeconds: 10
              successThreshold: 1
              timeoutSeconds: 3
            resources: {}
            securityContext:
              capabilities:
                drop:
                - ALL
              runAsGroup: 65532
              runAsNonRoot: true
              runAsUser: 65532
            startupProbe:
              failureThreshold: 20
              grpc:
                port: 4222
                service: ""
              periodSeconds: 3
              successThreshold: 1
              timeoutSeconds: 1
            terminationMessagePath: /dev/termination-log
            terminationMessagePolicy: FallbackToLogsOnError
            volumeMounts:
            - mountPath: /etc/hubble-relay
              readOnly: true
          dnsPolicy: ClusterFirst
          restartPolicy: Always
          schedulerName: default-scheduler
          securityContext:
            fsGroup: 65532
          serviceAccount: hubble-relay
          serviceAccountName: hubble-relay
          terminationGracePeriodSeconds: 1
          volumes:
          - configMap:
              defaultMode: 420
              items:
              - key: config.yaml
                path: config.yaml
    apiVersion: apps/v1
    kind: Deployment
      labels:
        app: hubble-ui
      replicas: 1
      selector:
        matchLabels:
          app: hubble-ui
      strategy:
        rollingUpdate:
          maxSurge: 25%
          maxUnavailable: 1
        type: RollingUpdate
      template:
          labels:
            app: hubble-ui
          automountServiceAccountToken: true
          containers:
          - image: quay.io/cilium/hubble-ui:v0.13.5
            livenessProbe:
              failureThreshold: 3
              httpGet:
                path: /healthz
                port: 8081
                scheme: HTTP
              periodSeconds: 10
              successThreshold: 1
              timeoutSeconds: 1
            ports:
            - containerPort: 8081
              protocol: TCP
            readinessProbe:
              failureThreshold: 3
              httpGet:
                path: /
                port: 8081
                scheme: HTTP
              periodSeconds: 10
              successThreshold: 1
              timeoutSeconds: 1
            resources: {}
            volumeMounts:
            - mountPath: /etc/nginx/conf.d/default.conf
              subPath: nginx.conf
            - mountPath: /tmp
          - env:
            - name: EVENTS_SERVER_PORT
              value: "8090"
            - name: FLOWS_API_ADDR
              value: hubble-relay:80
            image: quay.io/cilium/hubble-ui-backend:v0.13.5
            ports:
            - containerPort: 8090
              protocol: TCP
            resources: {}
          securityContext:
            fsGroup: 1001
            runAsGroup: 1001
            runAsUser: 1001
          serviceAccount: hubble-ui
          serviceAccountName: hubble-ui
          terminationGracePeriodSeconds: 30
          volumes:
          - configMap:
              defaultMode: 420
          - emptyDir: {}
  2. Deploy components.
    kubectl apply -f hubble.yaml
Step 3: Deploy the hubble-ui Service
You can deploy a Service of the NodePort or LoadBalancer type to provide the hubble-ui service externally.
A NodePort Service is used as an example here.
  1. Create the hubble-ui.yaml file.
    apiVersion: v1
    kind: Service
      labels:
        app: hubble-ui
      externalTrafficPolicy: Cluster
      ipFamilies:
      - IPv4
      ports:
      - name: http
        nodePort: 32222
        port: 80
        protocol: TCP
        targetPort: 8081
      selector:
        app: hubble-ui
      type: NodePort
  2. Create a NodePort Service.
    kubectl apply -f hubble-ui.yaml
Step 4: Access hubble-ui
Enter the external access address of hubble-ui in the browser, for example, http://{EIP-of-the-node}:32222.
Step 5: Install Add-ons
  1. Install the Cloud Native Cluster Monitoring and Grafana add-ons in the cluster.
    1. Install the Cloud Native Cluster Monitoring add-on. For details, see Cloud Native Cluster Monitoring.
    2. Install the Grafana add-on. For details, see Grafana.
  2. Create the hubble-monitor.yaml file.
    apiVersion: monitoring.coreos.com/v1
    kind: ServiceMonitor
      namespace: monitoring
      endpoints:
      - honorLabels: true
        path: /metrics
        port: hubble-metrics
        relabelings:
        - action: replace
          replacement: ${1}
          sourceLabels:
          - __meta_kubernetes_pod_node_name
          targetLabel: node
        scheme: http
      jobLabel: hubble
      namespaceSelector:
        matchNames:
        - kube-system
      selector:
        matchLabels:
          app: hubble
  3. Create a monitoring task.
    kubectl create -f hubble-monitor.yaml
Step 6: Configure the Hubble Metric Dashboard
The Cilium official website provides a Grafana dashboard for Hubble metrics. Compared with the monotonous metrics of Prometheus, the Grafana dashboard is more attractive. You can access the dashboard to view Hubble metrics.
  1. Prepare the Hubble metric dashboard configuration. Open the sample Prometheus file from the Cilium community, locate hubble-dashboard.json, and copy its contents.
  2. Log in to Grafana, choose Dashboards, and import the hubble-dashboard.json file.
    If you have enabled Interconnect with AOM when installing the Grafana add-on in Step 5: Install Add-ons, change the value of datasource in the hubble-dashboard.json file to prometheus-aom, and then import the file.
  3. Access the dashboard to view Hubble metrics. For details, see Hubble Metrics.
