Updated on 2025-11-06 GMT+08:00
DataPlane V2 Network Acceleration
DataPlane V2 can be enabled in clusters that use VPC networks or Cloud Native Network 2.0. This function supports eBPF redirection for applying network policies.
CCE DataPlane V2 is released with restrictions. To use this feature, submit a service ticket to CCE.
DataPlane V2
Technical implementation
DataPlane V2 integrates open-source Cilium to provide capabilities such as network policies.
Supported cluster versions
CCE standard clusters using VPC networks for commercial use of v1.27.16-r30, v1.28.15-r20, v1.29.13-r0, v1.30.10-r0, v1.31.6-r0, or later
CCE Turbo clusters in limited OBT of v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, or later
Usage
  • When creating a CCE standard cluster, select the VPC network in the container network configuration and enable DataPlane V2.
  • When creating a CCE Turbo cluster, select Cloud Native Network 2.0 and enable DataPlane V2.
NOTICE:
  • After DataPlane V2 is enabled, secure containers (Kata Containers as the container runtime) are not supported.
  • Enabled DataPlane V2 cannot be disabled.
  • DataPlane V2 can only be enabled for new clusters.
  • CCE Turbo DataPlane V2 is in limited OBT. Upgrading it to a commercial version requires the node to be reset. Exercise caution when enabling this function.
  • After DataPlane V2 is enabled, the Guaranteed Egress Network Bandwidth capability of cloud native hybrid deployment cannot be enabled.
  • If Layer 7 network policies or DNS-based policies are enabled for services in your cluster, the traffic that matches these policies will be disrupted during a Cilium upgrade. For details, see the constraints in the community.
Supported OS
Only Huawei Cloud EulerOS 2.0 is supported.
Accelerated data link
  • CCE standard cluster: When a pod accesses the cluster-scoped IP address or external IP address of a Service, eBPF is used to resolve the Service address to the address of a pod associated with the Service.
  • CCE Turbo cluster: N/A
Performance optimization
  • CCE standard cluster: After host routing is enabled, pods can bypass iptables- or IPVS-based forwarding and directly access Services using eBPF. This greatly reduces request latency. The network performance is less affected in large-scale clusters, and the scalability is better.
  • EDT is used to limit the egress bandwidth. This makes bandwidth limitation more accurate and resource consumption lower.
Bandwidth
After DataPlane V2 network acceleration is enabled, pods on the nodes running Huawei Cloud EulerOS 2.0 use EDT to limit the egress bandwidth. The ingress bandwidth limitation is not supported. If DataPlane V2 is not enabled, the TBF Qdisc is used to limit the bandwidth. For details, see Configuring QoS for Pods.
NetworkPolicy
  • The implementation of network policies is different from that of container tunnel networks. For details, see Configuring Network Policies to Restrict Pod Access.
    • The IPBlock selector can only select CIDR blocks outside a cluster.
    • The IPBlock selector does not have good support for the except keyword, so this keyword is not recommended.
    • If a network policy of the egress type is used, the pod fails to access the IP addresses of the hostNetwork pod and node in the cluster.
Resource consumption
The resident cilium-agent process on each node is responsible for eBPF network acceleration. Each cilium-agent process may occupy 80 MiB of memory. Each time a pod is added, the cilium-agent memory consumption may increase by 10 KiB.
Components
After DataPlane V2 is enabled, components listed in the following table are installed.
Component
Resource Type
cilium-operator
  • Synchronizes CRDs.
  • Removes the node.cilium.io/agent-not-ready taint of a node.
  • Tunes and recycles internal resources.
Deployment
yangtse-cilium
  • Installs the auxiliary CNI (cilium-cni) for CCE to adapt to Cilium.
  • Deploys cilium-agent.
DaemonSet
Configuration Management
You can use ConfigMaps to create custom network components of DataPlane V2.
ConfigMap Configuration
Configurable Component
Priority
yangtse-cilium-config
Default DataPlane V2 configuration. If this configuration is modified, the configuration will be restored to what it was during the cluster upgrade. Do not modify this configuration.
cilium-agent
cilium-config
Native configuration of the Cilium community. The priority of this configuration is lower than that of yangtse-cilium-config. If you need to create custom DataPlane V2 components, modify this configuration first.
cilium-agent
cilium-operator
2
Currently, only the Cilium add-on of 2.1.1 or later supports custom configuration.
Example custom network components:
  • Example 1: When cilium-agent is abnormal, you can configure --set-cilium-node-taints=true for cilium-operator to automatically add taints to a node to prevent pods from being scheduled to that node.
    You can create the following native ConfigMap configuration of the Cilium community:
    apiVersion: v1
    kind: ConfigMap
      namespace: kube-system
    data:
      set-cilium-node-taints: "true"
    After configuring cilium-config, you can run the following command to roll back and rebuild cilium-operator to apply the configuration:
    uuid=$(uuidgen)
    kubectl patch deployment -n kube-system cilium-operator --type='json' -p="[{\"op\": \"add\", \"path\": \"/spec/template/metadata/annotations/change-id\", \"value\": \"$uuid\"}]"
  • Example 2: If you want to enable Hubble of cilium-agent, you can create the following naive ConfigMap configuration of the Cilium community. For details about the parameter settings, see Deploying Hubble for DataPlane V2 Network Observability.
    apiVersion: v1
    kind: ConfigMap
    data:
      enable-hubble: "true"
      hubble-disable-tls: "true"
      hubble-listen-address: :4244
      hubble-metrics: dns drop tcp flow port-distribution icmp http
      hubble-metrics-server: :9965
    After configuring cilium-config, you can run the following command to roll back and rebuild yangtse-cilium to apply the configuration:
    uuid=$(uuidgen)
    kubectl patch daemonset -nkube-system yangtse-cilium --type='json' -p="[{\"op\": \"add\", \"path\": \"/spec/template/metadata/annotations/change-id\", \"value\": \"$uuid\"}]"
Change History
You can run the following command to check the cilium-operator image tag for the DataPlane V2 version:
kubectl get deploy -nkube-system cilium-operator -oyaml | grep "image:" | cut -d ':' -f 3
Information similar to the following is displayed:
2.1.1
Add-on Version
Status
Cluster Version
New Feature
Community Version
2.1.1
Commercial use
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
  • Support for only the CCE standard clusters that use VPC networks
  • Upgraded Cilium to v1.17.6.
  • Support for CCE standard clusters of v1.33
  • Custom Cilium parameters
  • Configurable Hubble observability
v1.17
2.0.2
OBT
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
  • Upgraded Cilium to v1.17.3.
  • Disabled bpf-lb-sock (by setting bpf-lb-sock=false).
  • Disabled host-based firewalls (by setting enable-host-firewall=false).
  • Enabled Layer 7 network policies (by setting enable-l7-proxy=true).
  • Enabled host-routing (by setting enable-host-legacy-routing=false).
v1.17
1.0.16
Limited OBT
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
  • Support for CCE Turbo clusters of v1.33
v1.14
1.0.15
Limited OBT
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.14
1.0.8
Limited OBT
v1.27
v1.28
v1.29
v1.30
v1.31
  • Supported CCE Turbo clusters that use Cloud Native 2.0 networks.
  • Disabled L7 network policies (by setting enable-l7-proxy=false).
v1.14
Add-on Version Differences
Add-on Version
Status
Cilium Version
Difference
Cluster Upgrade
2.x.x
Commercial use
v1.17
  • veth networking, fully compatible with Cilium
  • L7 network policies
  • Hubble network observability
When the cluster is upgraded, Cilium is automatically upgraded to the latest version.
1.x.x
OBT
v1.14
  • Network interface passthrough networking
  • No L7 network policies
When the cluster is upgraded, Cilium is not automatically upgraded. This version cannot be upgraded in-place upgrade to a commercial version. To upgrade to the latest commercial version, submit a service ticket to CCE for manual upgrade.
