Configuring GZIP Data Compression for a LoadBalancer Ingress
LoadBalancer ingresses support data compression, which reduces the size of files to be transferred, improves file transfer efficiency, and reduces the bandwidth needed for the transmission.
- This function relies on ELB capabilities. Before using this function, check whether it is supported in the current region. For details about the regions where this function is supported, see Elastic Load Balance Function Overview.
- After data compression is configured, if you delete the data compression configuration on the CCE console or delete the target annotation from the YAML file, the configuration on the ELB will be retained.
- A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
- v1.23: v1.23.14-r0 or later
- v1.25: v1.25.9-r0 or later
- v1.27: v1.27.6-r0 or later
- v1.28: v1.28.4-r0 or later
- Other clusters of later versions
- An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
- A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
Notes and Constraints
- Ingresses support GZIP data compression only when dedicated load balancers are used.
- If multiple ingresses share the same external port on a load balancer, you are advised to use the same GZIP compression configuration for these ingresses. Otherwise, the configuration of the first created ingress will take precedence. For details, see Configuring Multiple Ingresses to Use the Same External ELB Port.
You can configure GZIP data compression for an ingress using either the CCE console or kubectl.
- In the navigation pane, choose Services & Ingresses. Click the Ingresses tab and click Create Ingress in the upper right corner.
- Configure ingress parameters.
This example explains only key parameters for configuring GZIP data compression. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
Table 1 Key parameters Parameter
Example
Name
Enter an ingress name.
ingress-test
Load Balancer
Select a load balancer to be associated with the ingress or automatically create a load balancer. In this example, only dedicated load balancers are supported.
Dedicated
Listener
- Frontend Protocol: HTTP and HTTPS are available.
- External Port: specifies the port of the load balancer listener.
- Advanced Options
Data Compression: If this function is enabled, specific files will be compressed. If you do not enable this function, files will not be compressed.
Forwarding Policy
- Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
- Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
- Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
- Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
- Destination Service Port: Select the access port of the destination Service.
- Domain Name: You do not need to configure this parameter.
- Path Matching Rule: Prefix match
- Path: /
- Destination Service: nginx
- Destination Service Port: 80
Figure 1 Configuring GZIP data compression - Click OK.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
An example YAML file of an ingress associated with an existing load balancer is as follows:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.id: <your_elb_id> # Replace it with the ID of your existing load balancer. kubernetes.io/elb.class: performance # Load balancer type kubernetes.io/elb.port: '80' kubernetes.io/elb.gzip-enabled: 'true' # Enable data compression. spec: rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with the name of your target Service. port: number: 8080 # Replace 8080 with the port number of your target Service. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cce
Table 2 Key parameters Parameter
Type
String
- true: Data compression is enabled, and specific file types will be compressed.
- false: Data compression is disabled, and no files will be compressed. By default, data compression is disabled.
The files in the following format can be compressed:
- Brotli can compress all file formats.
- GZIP can compress the files of the following types: text/xml, text/plain, text/css, application/javascript, application/x-javascript, application/rss+xml, application/atom+xml, application/xml, and application/json
This function is available only for HTTP/HTTPS listeners of dedicated load balancers.
- Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test cce * 121.**.**.** 80 10s
