Help Center/ Cloud Container Engine/ User Guide/ Networking/ Services/ LoadBalancer/ Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Service
Updated on 2025-11-06 GMT+08:00
When using a LoadBalancer Service, you can configure a trustlist or blocklist to specify the IP addresses that are allowed or denied accessing a load balancer listener.
  • Trustlist: Only the IP addresses in the list can access the listener.
  • Blocklist: The IP addresses in the list are not allowed to access the listener.
After a blocklist or trustlist access policy is configured, if you delete the blocklist or trustlist access policy configuration on the CCE console or delete the target annotation from the YAML file, the configuration on the ELB will be retained.
  • A Kubernetes cluster is available and the cluster version meets the following requirements:
    • v1.23: v1.23.12-r0 or later
    • v1.25: v1.25.7-r0 or later
    • v1.27: v1.27.4-r0 or later
    • v1.28: v1.28.2-r0 or later
    • Other clusters of later versions
  • An IP address group has been created on the ELB console. For details, see Creating an IP Address Group.
Creating a LoadBalancer Service and Configuring a Blocklist/Trustlist Access Policy
  2. Choose Services & Ingresses in the navigation pane, click the Services tab, and click Create Service in the upper right corner.
  3. Configure Service parameters.
    • Service Name: Enter a service name, for example, service-acl.
    • Service Type: Select LoadBalancer.
    • Service Affinity: Select cluster level or node level as needed. For details about the differences, see Service Affinity (externalTrafficPolicy).
    • Selector: Add a label and click Confirm. The Service will use this label to select pods. You can also click Reference Workload Label to use the label of an existing workload. In the dialog box that is displayed, select a workload and click OK.
    • Load Balancer
      Select a load balancer to be accessed. Only load balancers in the same VPC as the cluster are supported. If no load balancer is available, click Create Load Balancer to create one on the ELB console. Alternatively, select Auto create to create a load balancer. For details about parameter settings, see Table 1.
    • Health Check: defaults to Global health check. You can configure this parameter as needed.
    • Port
      • Protocol: the protocol used by the Service.
      • Service Port: the port used by the Service. The port ranges from 1 to 65535.
      • Container Port: the port that the workload listens on. For example, Nginx uses port 80 by default.
    • Access Control
      • Inherit ELB Configurations: CCE does not modify the existing access control configurations on the ELB console.
      • Allow all IP addresses: No access control is configured.
      • Trustlist: Only the selected IP address group can access the load balancer.
      • Blocklist: The selected IP address group cannot access the load balancer.
      For clusters of v1.25.16-r10, v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, v1.31.1-r0, or later, when using a dedicated load balancer, you can select a maximum of five IP address groups at a time for access control.
  4. Click OK.
An example YAML file of a Service created using an existing load balancer is as follows:
apiVersion: v1
kind: Service
  annotations:
    kubernetes.io/elb.id: <your_elb_id>                    # Load balancer ID. Replace it with the actual value.
    kubernetes.io/elb.class: performance                   # Load balancer type
    kubernetes.io/elb.acl-id: <your_acl_id>               # ID of an IP address group for accessing a load balancer
    kubernetes.io/elb.acl-status: 'on'                  # Enable access control.
    kubernetes.io/elb.acl-type: 'white'                   # Trustlist for access control
  selector:
     app: nginx
  ports:
  - name: service0
    port: 80
    protocol: TCP
    targetPort: 80
  type: LoadBalancer
Table 1 Annotations for ELB access control
Type
String
  • If this parameter is not specified, CCE does not modify access control on the ELB.
  • If this parameter is left empty, all IP addresses are allowed to access the load balancer.
  • If this parameter is set to the IP address group ID of the load balancer, access control is enabled and you need to configure an IP address blocklist or trustlist for the load balancer. Additionally, you need to configure both kubernetes.io/elb.acl-status and kubernetes.io/elb.acl-type.
    For clusters of v1.25.16-r10, v1.27.16-r10, v1.28.15-r0, v1.29.10-r0, v1.30.6-r0, v1.31.1-r0, or later, when using a dedicated load balancer, you can select a maximum of five IP address groups at a time, separated by commas (,).
    How to obtain:
    Log in to the ELB console, choose Elastic Load Balance > IP Address Groups, and copy the ID of the target IP address group. For details, see Creating an IP Address Group.
String
This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
  • on or true: Access control is enabled.
  • off or false: Access control is disabled.
String
  • black: indicates a blocklist. The selected IP address group cannot access the load balancer.
  • white: indicates a trustlist. Only the selected IP address group can access the load balancer.
Verifying Configuration
  2. In the navigation pane, choose Services & Ingresses. Locate the row that contains the created Service and click the load balancer name to go to the ELB console.
  3. Switch to the Listeners tab, locate the listener of the created port, and check whether the option is enabled.
