On this page
Host View
Updated on 2024-08-16 GMT+08:00
The host view displays information about host resource usage and health status, as well as common metrics of system devices such as disks and file systems, so you can better monitor a node.
Metric Description
You can view the host metrics in the following table.
Figure 1 Host metrics
Table 1 Host metrics
Metric
Unit
CPU Usage
Usage of each CPU core.
Load Average
N/A
CPU contention.
  • If the value is less than 1, some CPU resources are used for processing requests.
  • If the value is 1, all CPU resources are used for processing requests.
  • If the value is greater than 1, some threads are waiting for processing.
Used Memory
byte
Memory usage in each mode.
Memory Usage
Host memory usage.
Disk Written
byte/s
Write rate of each disk.
Disk Read
byte/s
Read rate of each disk.
Used Disk Space
byte
Used and available disk space.
Disk Space Usage
Disk usage of each device.
Disk I/O Latency
second
Disk I/O read/write latency, in seconds.
TCP Connection
N/A
The number of TCP sockets.
  • alloc: the number of TCP sockets allocated (established, and sk_buff obtained).
  • inuse: the number of TCP sockets in use (listening)
  • orphan: the number of TCP sockets not associated with applications.
  • tw: the number of TCP sockets waiting to be closed.
UDP Usage
N/A
UDP usage.
  • liteInuse: the number of UDP-Lite sockets in use.
  • inuse: the number of UDP sockets in use.
  • useMemory: the usage of the UPD buffer.
File Descriptor
exabyte
Maximum number of file descriptors.
Used File Descriptor
N/A
The number of allocated file descriptors.
Socket Usage
N/A
Socket usage.
  • socketsUsed: the total number of used protocol sockets.
  • fragInuse: the number of fragment sockets in use.
  • fragMemroy: the usage of the fragment buffer.
  • rawInuse: the number of raw sockets in use.
Abnormal File System
N/A
File system status.
  • readonly: The file system is read-only.
  • deviceError: A file system error occurred.
Disk I/O Rate
N/A
The number of read/write operations on a disk per second.
Disk Read/Write Latency
second
Disk read/write latency.
I/O Queues
N/A
Average I/O queue length of the disk device, which is the weighted number of seconds spent doing I/O operations. A larger value indicates better disk performance of the node.
Process State
N/A
The number of processes in each state.
Connection Tracking Table Entries
N/A
  • Allocated: the number of allocated entries in the connection tracking table.
  • Total: the maximum number of entries in the connection tracking table.
Metric List
The following is the metric list of the host view.
Table 2 Metric description
Metric
Type
node_cpu_seconds_total
Counter
Seconds the CPUs spent in each mode.
node_load1
Gauge
Average CPU load within 1 minute, which reflects the competition of CPU resources.
  • If the value is less than 1, some CPU resources are processing requests.
  • If the value is 1, all CPU resources are processing requests.
node_load15
Gauge
Average CPU load within 15 minutes.
node_memory_MemTotal_bytes
Gauge
Total memory of a node.
node_memory_MemAvailable_bytes
Gauge
Available memory of a node.
node_disk_written_bytes_total
Gauge
Total number of bytes written successfully.
node_disk_read_bytes_total
Gauge
Total number of bytes read successfully.
node_filesystem_size_bytes
Gauge
File system size in bytes.
node_filesystem_avail_bytes
Gauge
Available file system size in bytes.
node_disk_io_time_seconds_total
Counter
Total seconds spent doing I/O operations.
node_sockstat_TCP_alloc
Gauge
The number of allocated TCP sockets.
node_sockstat_UDPLITE_inuse
Gauge
The number of used UDPLITE sockets.
node_filefd_maximum
Gauge
File descriptor statistics: maximum.
node_filefd_allocated
Gauge
File descriptor statistics: allocated.
node_sockstat_sockets_used
Gauge
The number of used IPv4 sockets.
node_filesystem_readonly
Gauge
Read-only status of the file system.
node_disk_reads_completed_total
Counter
The number of disk reads completed.
node_disk_read_time_seconds_total
Counter
Total number of seconds spent by all reads.
node_disk_io_time_weighted_seconds_total
Counter
The weighted number of seconds spent doing I/O operations. A larger value indicates better disk performance of the node.
node_procs_blocked
Gauge
The number of processes blocked waiting for I/O to complete.
node_nf_conntrack_entries
Gauge
The number of currently allocated flow entries for connection tracking.
