Configuring URL Redirection for a LoadBalancer Ingress
Updated on 2025-02-18 GMT+08:00
Ingress can redirect specific access requests to a specified path. The following is an example of YAML file for configuring an ingress redirection rule. In this example, the request for accessing example.com is redirected to example.com/testa and status code 301 is returned.
  • A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
    • v1.23: v1.23.14-r0 or later
    • v1.25: v1.25.9-r0 or later
    • v1.27: v1.27.6-r0 or later
    • v1.28: v1.28.4-r0 or later
    • Other clusters of later versions
  • An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
Notes and Constraints
Configuring a Rule for Redirecting an Ingress to a URL
You can configure a rule for redirecting an ingress to a URL using either the CCE console or kubectl.
  2. Choose Services & Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    This example explains only key parameters for configuring URL redirection. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
    Table 1 Key parameters
    Example
    Name
    Enter an ingress name.
    ingress-test
    Load Balancer
    Select a load balancer to be associated with the ingress or automatically create a load balancer. In this example, only dedicated load balancers are supported.
    Dedicated
    Listener
    • External Protocol: HTTP and HTTPS are available.
    • External Port: specifies the port of the load balancer listener.
    • External Port: 80
    Forwarding Policy
    • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
    • Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
    • Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
    • Destination Service: Select an existing Service or create a Service. Any Services that do not match the search criteria will be filtered out automatically.
    • Destination Service Port: Select the access port of the destination Service.
    • Actions
      • Operation: Select Redirect to URL. When an access request meets the forwarding policy, the request will be redirected to a specified URL, and a specific status code will be returned.
      • URL: A URL starting with http:// or https:// is valid.
        HTTP routes can be redirected to HTTP or HTTPS routes. HTTPS routes can be redirected only to HTTPS routes.
      • StatusCode: The return code can be 301, 302, 303, 307, or 308.
    • Domain Name: example.com
    • Path Matching Rule: Prefix match
    • Path: /
    • Destination Service: nginx
    • Destination Service Port: 80
    • Actions:
      • Operation: Redirect to URL
      • URL: https://example.com/testa
      • StatusCode: 301
    Figure 1 Configuring a rule for redirecting an ingress to a URL
  4. Click OK.
An ingress can be redirected to a URL using annotations. Example:
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress associated with an existing load balancer is as follows:
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.id: df76342f-e898-402a-bac8-bde5bf974da8
        kubernetes.io/elb.class: performance
        kubernetes.io/elb.port: '80'
        kubernetes.io/elb.redirect-url: https://example.com/testa        # Information about the redirection to a URL
        kubernetes.io/elb.redirect-url-code: '301'     # Code returned after the ingress is redirected to a URL
      rules:
        - host: "example.com"
          http:
            paths:
              - path: /
                backend:
                  service:
                    port:
                      number: 80
                property:
      ingressClassName: cce
    Table 2 Key parameters
    Mandatory
    Type
    Yes
    String
    URL for redirection
    Format: A valid URL must start with http:// or https://, for example, https://example.com/.
    Parameter: This configuration takes effect on all forwarding rules of a single ingress. After the configuration is deleted, the target URL redirection rule will be automatically cleared.
    Either this annotation or the annotation of a grayscale release can be configured.
    No
    String
    Code returned after an ingress is redirected to a URL.
    Format: The return code can be 301, 302, 303, 307, or 308.
    Parameter: The default value is 301.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/test-redirect-url created
  4. Check the created ingress.
    kubectl get ingress
    NAME               CLASS    HOSTS         ADDRESS          PORTS   AGE
    test-redirect-url  cce      example.com   121.**.**.**     80      10s
  5. Use curl to verify the redirection, where ${ELB_IP} is the IP address accessed by the target ingress.
    curl -I -H "Host:example.com" ${ELB_IP}
    The access path will be redirected to example.com/testa.
    HTTP/1.1 301 Moved Permanently
    Date: Thu, 07 Mar 2024 11:04:31 GMT
    Content-Type: text/html
    Content-Length: 134
    Connection: keep-alive
    Server: elb
    Example
    Name
    ingress-test
    Load Balancer
    Dedicated
    Listener
    • External Port: 80
    Forwarding Policy
    • Actions
    • Path: /
    • Actions:
      • StatusCode: 301
  4. Click OK.
    kind: Ingress
      namespace: default
      annotations:
      rules:
          http:
            paths:
              - path: /
                backend:
                  service:
                    port:
                      number: 80
                property:
    Mandatory
    Type
    Yes
    String
    URL for redirection
    No
    String
    kubectl get ingress
    Content-Length: 134
    Server: elb
