Configuring an HTTPS Certificate for a LoadBalancer Ingress
Updated on 2025-02-18 GMT+08:00
Ingresses support SSL or TLS certificates, allowing you to secure your Services with HTTPS.
You are allowed to use either of the following ways to configure an ingress certificate in a cluster:
  • Using a TLS Certificate: You need to first import a certificate to a secret. CCE will then automatically handle the certificate configurations on the ELB console and give a name to the certificate (started with k8s_plb_default). This certificate, which is generated by CCE, cannot be modified or deleted from the ELB console. To modify the certificate, update the secret where the certificate is imported to on CCE.
  • Using a Certificate Created on the ELB Console: You are allowed to directly use certificates created on the ELB console. There is no need to manually configure the cluster Secrets, and you can modify the certificates on the ELB console.
If multiple ingresses share the same external port on a load balancer, you are advised to use the same certificate and security policy for these ingresses. Otherwise, the configuration of the first created ingress will take precedence. For details, see Configuring a Same Port for Multiple Ingresses.
You can configure a TLS certificate using either the CCE console or kubectl.
  2. Choose Services & Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    This example explains only key parameters for configuring HTTPS certificates. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
    Table 1 Key parameters
    Example
    Name
    Enter an ingress name.
    ingress-test
    Load Balancer
    Select a load balancer to be associated with the ingress or automatically create a load balancer.
    Shared
    Listener
    • External Protocol: Select HTTPS when configuring a certificate for an ingress.
    • External Port: specifies the port of the load balancer listener. The default HTTPS port is 443.
    • Certificate Source: Select TLS secret.
    • Server Certificate: kubernetes.io/tls and IngressTLS are supported.
      If no certificate is available, you can create a TLS certificate. For details about the configuration parameters, see Creating a Secret.
    • External Protocol: HTTPS
    • External Port: 443
    • Certificate Source: TLS secret
    • Server Certificate: test
    Forwarding Policy
    • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
    • Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
    • Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
    • Destination Service: Select an existing Service or create a Service. Any Services that do not match the search criteria will be filtered out automatically.
    • Destination Service Port: Select the access port of the destination Service.
    • Domain Name: You do not need to configure this parameter.
    • Path Matching Rule: Prefix match
    • Path: /
    • Destination Service: nginx
    • Destination Service Port: 80
    Figure 1 Selecting a TLS certificate
  4. Click OK.
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Ingress supports two TLS secret types: kubernetes.io/tls and IngressTLS. IngressTLS is used as an example. For details, see Creating a Secret. For details about examples of the kubernetes.io/tls secret and its description, see TLS secrets.
    Create a YAML file named ingress-test-secret.yaml. The file name can be customized.
    vi ingress-test-secret.yaml
    The YAML file is configured as follows:
    apiVersion: v1
    data:
      tls.crt: LS0******tLS0tCg==
      tls.key: LS0tL******0tLS0K
    kind: Secret
      annotations:
        description: test for ingressTLS secrets
      namespace: default
    type: IngressTLS
    In the preceding information, tls.crt and tls.key are only examples. Replace them with the actual files. The values of tls.crt and tls.key are Base64-encoded.
  3. Create a secret.
    kubectl create -f ingress-test-secret.yaml
    If information similar to the following is displayed, the secret has been created:
    secret/ingress-test-secret created
  4. Check the created secret.
    kubectl get secrets
    NAME                         TYPE                                  DATA      AGE
    ingress-test-secret          IngressTLS                            2         13s
  5. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    Default security policy (kubernetes.io/elb.tls-ciphers-policy) is supported only in clusters of v1.17.17 or later.
    Custom security policy (kubernetes.io/elb.security_policy_id) is supported only in clusters of v1.17.17 or later.
    An example YAML file of an ingress associated with an automatically created load balancer is as follows:
    For clusters of v1.21 or earlier:
    apiVersion: networking.k8s.io/v1beta1
    kind: Ingress
      annotations:
        kubernetes.io/elb.class: performance
        kubernetes.io/ingress.class: cce
        kubernetes.io/elb.port: '443'
        kubernetes.io/elb.autocreate:
              "type": "public",
              "bandwidth_name": "cce-bandwidth-******",
              "bandwidth_chargemode": "bandwidth",
              "bandwidth_size": 5,
              "bandwidth_sharetype": "PER",
              "eip_type": "5_bgp",
              "available_zone": [
                  "ap-southeast-1a"
              "elb_virsubnet_ids":["b4bf8152-6c36-4c3b-9f74-2229f8e640c9"],
              "l7_flavor_name": "L7_flavor.elb.s1.small"
        kubernetes.io/elb.security_policy_id: 99bec42b-0dd4-4583-98e9-b05ce628d157  # The priority of the custom security policy is higher than that of the default security policy.
        kubernetes.io/elb.tls-ciphers-policy: tls-1-2
      tls:
      - secretName: ingress-test-secret
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              serviceName: <your_service_name>  # Replace it with the name of your target Service.
              servicePort: 80
            property:
    For clusters of v1.23 or later:
    kind: Ingress
      annotations:
              "type": "public",
              "available_zone": [
                  "ap-southeast-1a"
      tls:
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              service:
                name: <your_service_name>  # Replace it with the name of your target Service.
                port:
                  number: 80             # Replace 80 with the port number of your target Service.
            property:
      ingressClassName: cce
    Table 2 Key parameters
    Mandatory
    Type
    No
    String
    The ID of the custom security group policy on ELB. Obtain it on the ELB console. This field takes effect only when HTTPS is used and has a higher priority than the default security policy.
    For details about how to create and update a custom security policy, see TLS Security Policy.
    No
    String
    The default value is tls-1-2, which is the default security policy used by the listener and takes effect only when HTTPS is used.
    Options:
    • tls-1-0
    • tls-1-1
    • tls-1-2
    • tls-1-2-strict
    • tls-1-0-with-1-3 (dedicated load balancer)
    • tls-1-2-fs (dedicated load balancer)
    • tls-1-2-fs-with-1-3 (dedicated load balancer)
    For details of cipher suites for each security policy, see Table 3.
    tls
    No
    Array of strings
    When HTTPS is used, this parameter must be added to specify the secret certificate.
    Multiple independent domain names and certificates can be added. For details, see Configuring SNI for a LoadBalancer Ingress.
    secretName
    No
    String
    This parameter is mandatory if HTTPS is used. Set this parameter to the name of the created secret.
    Table 3 tls_ciphers_policy parameters
    Security Policy
    TLS Version
    Cipher Suite
    tls-1-0
    TLS 1.2
    TLS 1.1
    TLS 1.0
    ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:AES128-SHA256:AES256-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:AES128-SHA:AES256-SHA
    tls-1-1
    TLS 1.2
    TLS 1.1
    tls-1-2
    TLS 1.2
    tls-1-2-strict
    TLS 1.2
    TLS 1.3
    TLS 1.2
    TLS 1.1
    TLS 1.0
    ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:AES128-SHA256:AES256-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:AES128-SHA:AES256-SHA:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:TLS_AES_128_CCM_8_SHA256:TLS_AES_128_CCM_SHA256
    TLS 1.3
    TLS 1.2
    ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384
    TLS 1.3
    TLS 1.2
    ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA256:TLS_AES_128_CCM_8_SHA256:TLS_AES_128_CCM_SHA256
  6. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/ingress-test created
  7. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS     ADDRESS          PORTS   AGE
    ingress-test  cce      *         121.**.**.**     80,443  10s
  8. Enter https://121.**.**.**:443 in the address box of the browser to access the workload (for example, Nginx workload).
    121.**.**.** indicates the IP address of the unified load balancer.
    Example
    Name
    ingress-test
    Load Balancer
    Shared
    Listener
    Forwarding Policy
    • Path: /
  4. Click OK.
    apiVersion: v1
    data:
    kind: Secret
      annotations:
      namespace: default
    type: IngressTLS
  3. Create a secret.
    kubectl get secrets
    NAME                         TYPE                                  DATA      AGE
    kind: Ingress
      annotations:
              "type": "public",
              "available_zone": [
                  "ap-southeast-1a"
      tls:
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              servicePort: 80
            property:
    kind: Ingress
      annotations:
              "type": "public",
              "available_zone": [
                  "ap-southeast-1a"
      tls:
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              service:
                port:
            property:
    Mandatory
    Type
    No
    String
    No
    String
    Options:
    • tls-1-0
    • tls-1-1
    • tls-1-2
    • tls-1-2-strict
    tls
    No
    Array of strings
    secretName
    No
    String
    Security Policy
    TLS Version
    Cipher Suite
    tls-1-0
    TLS 1.2
    TLS 1.1
    TLS 1.0
    tls-1-1
    TLS 1.2
    TLS 1.1
    tls-1-2
    TLS 1.2
    tls-1-2-strict
    TLS 1.2
    TLS 1.3
    TLS 1.2
    TLS 1.1
    TLS 1.0
    TLS 1.3
    TLS 1.2
    TLS 1.3
    TLS 1.2
    kubectl get ingress
You can configure a certificate created on the ELB console for an ingress through either the CCE console or kubectl.
  • If both an ELB certificate and a TLS certificate are specified for the same ingress, the ingress will use the ELB certificate.
  • CCE does not check whether an ELB certificate is valid. It only checks whether the certificate is present.
  • Only ingresses in clusters of v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later support ELB certificates.
    Table 4 Key parameters
    Example
    Name
    ingress-test
    Load Balancer
    Shared
    Listener
    • External Protocol: Select HTTPS.
    • Certificate Source: Select ELB server certificate.
    • Server Certificate: Use a certificate created on ELB.
      If no certificate is available, go to the ELB console and create one. For details, see Adding a Certificate.
    • Certificate Source: ELB server certificate
    • Server Certificate: cert-test
    Forwarding Policy
    • Path: /
    Figure 2 Selecting a certificate from the ELB service
  4. Click OK.
To use an ELB certificate, you can specify the kubernetes.io/elb.tls-certificate-ids annotation.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    An example YAML file of an ingress associated with an existing load balancer is as follows:
    kind: Ingress
      annotations:
        kubernetes.io/elb.id: 0b9a6c4d-bd8b-45cc-bfc8-ff0f9da54e95
        kubernetes.io/elb.class: union
        kubernetes.io/elb.tls-certificate-ids: 058cc023690d48a3867ad69dbe9cd6e5,b98382b1f01c473286653afd1ed9ab63
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              servicePort: 80
            property:
    kind: Ingress
      namespace: default
      annotations:
      rules:
        - host: ''
          http:
            paths:
              - path: '/'
                backend:
                  service:
                    port:
                property:
    Table 5 Key parameters
    Type
    String
    ELB certificate IDs, which are separated by comma (,). The list length is greater than or equal to 1. The first ID in the list is the server certificate, and the other IDs are SNI certificates in which a domain name must be contained.
    If an SNI certificate cannot be found based on the domain name requested by the client, the server certificate will be returned by default.
    To obtain the certificate, log in to the CCE console, choose Service List > Networking > Elastic Load Balance, and click Certificates in the navigation pane. In the load balancer list, copy the ID under the target certificate name.
  3. Create an ingress.
  4. Check the created ingress.
    kubectl get ingress
    Example
    Name
    ingress-test
    Load Balancer
    Shared
    Listener
    Forwarding Policy
    • Path: /
  4. Click OK.
    kind: Ingress
      annotations:
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              servicePort: 80
            property:
    kind: Ingress
      namespace: default
      annotations:
      rules:
        - host: ''
          http:
            paths:
              - path: '/'
                backend:
                  service:
                    port:
                property:
    Type
    String
    kubectl get ingress
In a cluster, multiple ingresses can share a listener, allowing them to use the same port on a single load balancer. When two ingresses are set up with HTTPS certificates, the server certificate that is used will be based on the configuration of the earliest ingress. For details, see How Can I Determine Which Ingress the Listener Settings Have Been Applied To?
Starting from v1.21.15-r0, v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, v1.29.1-r0, and later, the YAML file of ingresses includes annotation: kubernetes.io/elb.listener-master-ingress. This annotation specifies the server certificate configured and used by ingresses.
For example, the configurations of two ingresses are as follows:
Ingress Name
ingress1
ingress2
Namespace
default
default
Creation Time
2024-04-01
2024-04-02
Protocol
HTTPS
HTTPS
Load Balancer
elb1
elb1
Port
443
443
default/ingress1
default/ingress1
In the configurations of the two ingresses, annotation: kubernetes.io/elb.listener-master-ingress is present and the value is default/ingress1, indicating that the server certificates that take effect for the two ingresses are the server certificates configured for ingress1 in the default namespace.
If ingresses in separate namespaces use the same listener and TLS certificates, the secrets associated with the TLS certificates may not display normal for the later-created ingress due to namespace isolation. For details, see How Can I Synchronize Certificates When Multiple Ingresses in Different Namespaces Share a Listener?
To update a server certificate, modify the certificate in the ingress1 configuration within the default namespace. Once the modification is made, the certificates used by both ingress1 and ingress2 will be updated accordingly.
To find the ingress with the active certificate configuration, run the following command:
kubectl get ingress -n ${namespace} ${ingress_name}  -oyaml | grep kubernetes.io/elb.listener-master-ingress
