Using an SFS File System Through a Dynamic PV
This section describes how to use StorageClasses to dynamically create PVs and PVCs for data persistence and sharing in workloads.
- You have created a cluster and installed the CCE Container Storage (Everest) add-on in the cluster.
- To create a cluster using commands, ensure kubectl is used. For details, see Accessing a Cluster Using kubectl.
- Before using a general purpose file system (SFS 3.0 Capacity-Oriented) for storage, ensure a VPC endpoint has been created in the VPC where the cluster is located for the cluster to access the file system. For details, see Configuring a VPC Endpoint.
- If a general purpose file system (SFS 3.0 Capacity-Oriented) is used, CCE Container Storage (Everest) of v2.0.9 or later must be installed in the cluster.
- If a general purpose file system (SFS 3.0 Capacity-Oriented) is used, the owner group and permission of the mount point cannot be modified. The default owner of the mount point is user root.
- If a general purpose file system (SFS 3.0 Capacity-Oriented) is used, there may be a latency during the creation or deletion of PVCs and PVs. The billing duration is determined by the time when the resource is created or deleted on the SFS console.
- If the CCE Container Storage (Everest) version is earlier than 2.4.105 or the target region is CN South-Guangzhou, and the Delete reclaim policy is used for the general purpose file system (SFS 3.0 Capacity-Oriented), you must delete files from the file system. Otherwise, deleting the PVs and PVCs may fail. If the add-on version is 2.4.105 or later and the region is not CN South-Guangzhou, this restriction does not apply.
Dynamically Creating an SFS File System
CCE allows you to create SFS PVCs via the console or kubectl based on the configured StorageClasses. After PVC creation, CCE dynamically allocates storage resources and mounts the PVCs to the specified workloads. To do so, perform the following operations.
- Dynamically create a PVC and PV.
- Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click Create PVC in the upper right corner. In the dialog box displayed, configure PVC parameters.
PVC Type
In this example, select SFS.
PVC Name
Enter the PVC name, which must be unique in a namespace.
Creation Method
- If no underlying storage is available, select Dynamically provision to create a PVC, PV, and underlying storage on the console in cascading mode.
- If underlying storage is available, create a PV or use an existing PV to statically create a PVC. For details, see Using an Existing SFS File System Through a Static PV.
In this example, select Dynamically provision.
Storage Classes
The default StorageClass of SFS volumes is csi-sfs.
You can customize a StorageClass and configure its reclaim policy and binding mode. For details, see Through the Console.
(Optional) Storage Volume Name Prefix
Available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest v2.4.15 or later is installed in the cluster.
This parameter specifies the name of the underlying storage that is automatically created. The actual underlying storage name is in the format of "Storage volume name prefix + PVC UID". If this parameter is left blank, the default prefix pvc will be used.
For example, if the storage volume name prefix is set to test, the actual underlying storage name is test-{UID}.
Access Mode
SFS volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple nodes in read/write mode. For details, see Volume Access Modes.
- Click Create to create a PVC and a PV.
You can choose Storage in the navigation pane and view the created PVC and PV on the PVCs and PVs tabs, respectively.
- Create an application.
- Choose Workloads in the navigation pane. In the right pane, click the Deployments tab.
- Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Information area under Container Settings and choose Add Volume > PVC.
Mount and use storage volumes. For details about the parameters, see Table 1. For other parameters, see Workloads.
Table 1 Mounting a storage volume Parameter
PVC
Select an existing SFS volume.
Mount Path
Enter a mount path, for example, /tmp.
This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. This may lead to container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.NOTICE:If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
Subpath
Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path will be used by default.
Permission
- Read-only: You can only read the data in the mounted volumes.
- Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the SFS file system.
- After the configuration, click Create Workload.
After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence and Sharing.
- Use kubectl to access the cluster.
- Use StorageClass to dynamically create a PVC and PV.
- Create the pvc-sfs-auto.yaml file.
apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-sfs-auto namespace: default annotations: everest.io/csi.volume-name-prefix: test # (Optional) Storage volume name prefix of the automatically created underlying storage spec: accessModes: - ReadWriteMany # The value must be ReadWriteMany for SFS. resources: requests: storage: 1Gi # SFS volume capacity storageClassName: csi-sfs # The StorageClass is SFS. csi-sfs indicates that a general purpose file system (SFS 3.0 Capacity-Oriented) is used.Table 2 Key parameters Parameter
Mandatory
storage
Yes
Requested capacity in the PVC, in Gi.
For SFS, this parameter is only for verification. It must not be empty or 0, and its value is fixed at 1. Any value you set will not take effect.
storageClassName
Yes
StorageClass name, which must be csi-sfs, indicating that a general purpose file system (SFS 3.0 Capacity-Oriented) is used.
No
(Optional) This parameter is available only when the cluster version is v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later, and Everest v2.4.15 or later is installed in the cluster.
Enter 1 to 26 characters that cannot start or end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
- Run the following command to create a PVC:
kubectl apply -f pvc-sfs-auto.yaml
- Create a file named web-demo.yaml. In this example, the SFS volume is mounted to the /data path.
apiVersion: apps/v1 kind: Deployment metadata: name: web-demo namespace: default spec: replicas: 2 selector: matchLabels: app: web-demo template: metadata: labels: app: web-demo spec: containers: - name: container-1 image: nginx:latest volumeMounts: - name: pvc-sfs-volume # Volume name, which must be the same as the volume name in the volumes field mountPath: /data # Location where the storage volume is mounted imagePullSecrets: - name: default-secret volumes: - name: pvc-sfs-volume # Volume name, which can be customized persistentVolumeClaim: claimName: pvc-sfs-auto # Name of the created PVC - Run the following command to create a workload to which the SFS volume is mounted:
kubectl apply -f web-demo.yaml
- View the deployed application and files.
- Run the following command to view the created pod:
kubectl get pod -n <namespace> | grep web-demo
Expected output:web-demo-846b489584-mjhm9 1/1 Running 0 46s web-demo-846b489584-wvv5s 1/1 Running 0 46s
- Run the following commands in sequence to check the files in the /data path of the pods:
kubectl exec -n <namespace> web-demo-846b489584-mjhm9 -- ls /data kubectl exec -n <namespace> web-demo-846b489584-wvv5s -- ls /data
If no result is returned for both pods, no file exists in the /data path.
- Run the following command to create a file named static in the /data path:
kubectl exec -n <namespace> web-demo-846b489584-mjhm9 -- touch /data/static
- Run the following command to check the files in the /data path:
Expected output:
static
- Verify data persistence.
- Run the following command to delete the pod named web-demo-846b489584-mjhm9:
kubectl delete pod -n <namespace> web-demo-846b489584-mjhm9
Expected output:
pod "web-demo-846b489584-mjhm9" deleted
After the deletion, the Deployment controller automatically creates a replica.
The expected output is as follows, in which web-demo-846b489584-d4d4j is the newly created pod:web-demo-846b489584-d4d4j 1/1 Running 0 110s web-demo-846b489584-wvv5s 1/1 Running 0 7m50s
- Run the following command to check whether the files in the /data path of the new pod have been modified:
kubectl exec -n <namespace> web-demo-846b489584-d4d4j -- ls /data
Expected output:
static
The static file is retained, indicating that the data in the file system can be stored persistently.
- Verify data sharing.
Expected output:web-demo-846b489584-d4d4j 1/1 Running 0 7m web-demo-846b489584-wvv5s 1/1 Running 0 13m
- Run the following command to create a file named share in the /data path of either pod: In this example, select the pod named web-demo-846b489584-d4d4j.
kubectl exec -n <namespace> web-demo-846b489584-d4d4j -- touch /data/share
Check the files in the /data path of the pod.kubectl exec -n <namespace> web-demo-846b489584-d4d4j -- ls /data
Expected output:
share static
- Check whether the share file exists in the /data path of another pod (web-demo-846b489584-wvv5s) as well to verify data sharing.
Expected output:
share static
After you create a file in the /data path of a pod, if the file is also created in the /data path of the other pod, the two pods share the same volume.
Related Operations
Operation |
Description |
Procedure |
Viewing events |
View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV. |
Viewing a YAML file |
View, copy, or download the YAML file of a PVC or PV. |
Editing Reclaim Policy |
Modify the reclaim policy of a PV. |
Synchronizing PVC capacity (supported only for PVCs created from non-subdirectories of SFS Capacity-Oriented file systems) |
When the underlying storage outgrows the PVC, resize the PVC capacity on the CCE console to match the new size. |
Common Issues
Mounting a general purpose file system (SFS 3.0 Capacity-Oriented) timed out, and the error message is as follows:
MountVolume.SetUp failed for volume "***" : rpc error: code = Internal desc = [30834707-b8fc-11ee-ba7a-fa163eaacb17] failed to execute cmd: "systemd-run --scope mount -t nfs -o proto=tcp -o vers=3 -o timeo=600 -o noresvport -o nolock ***.sfs3.cn-east-3.myhuaweicloud.com:/*** /mnt/paas/kubernetes/kubelet/pods/add9a323-10e2-434f-b151-42675f83860e/volumes/kubernetes.io~csi/***/mount". outputs: Running scope as unit run-1597979.scope.; error: signal: killed. please check whether the volumeAttributes of related PersistentVolume of the volume is correct and whether it can be mounted.
Solution
Create a VPC endpoint before using a general purpose file system (SFS 3.0 Capacity-Oriented). Otherwise, the cluster cannot access the general purpose file system. As a result, the mounting times out and fails. For details, see Configuring a VPC Endpoint.
