Updated on 2026-06-16 GMT+08:00
NodeLocal DNSCache
Introduction
The NodeLocal DNSCache add-on (formerly node-local-dns) is developed based on the community NodeLocal DNSCache. This add-on functions as a DaemonSet to run the DNS cache proxy on each cluster node to improve cluster DNS performance.
Open-source community: https://github.com/kubernetes/dns
After NodeLocal DNSCache is enabled, a DNS query goes through the path as shown below.
Figure 1 NodeLocal DNSCache query path
The resolution lines are described as follows:
  • 1. By default, the pods with DNSConfig injected use NodeLocal DNSCache to resolve requested domain names.
  • 2. If NodeLocal DNSCache cannot resolve domain names, it will ask CoreDNS for resolution.
  • 3. CoreDNS resolves domain names outside the cluster by using the DNS server in the VPC.
  • 4. If a pod with DNSConfig injected cannot access NodeLocal DNSCache, CoreDNS will resolve the domain name.
  • 5. By default, CoreDNS resolves domain names for the pods without DNSConfig injected.
Notes and Constraints
  • This add-on is available only in clusters v1.19 or later.
Installing the Add-on
  2. In the navigation pane, choose Add-ons. Locate NodeLocal DNSCache on the right and click Install.
  3. On the Install Add-on page, configure the specifications as needed.
    • If you selected Preset, you can choose between Standalone or HA based on the cluster scale. The system will automatically set the number of add-on pods and resource quotas according to the preset specifications. You can see the configurations on the console.
      Standalone means that a DNSConfig admission controller is deployed on a single pod, which consumes few resources. HA means that DNSConfig admission controllers are deployed on two pods, which enhances the availability of the add-on.
    • If you selected Custom, you can adjust the number of pods and resource quotas as needed. High availability is not possible with a single pod. If an error occurs on the node where the add-on pod runs, the add-on will fail.
  4. Configure the add-on parameters.
    • DNSConfig: After this function is enabled, a DNSConfig admission controller will be created. The controller intercepts pod creation requests in the namespace labeled with node-local-dns-injection=enabled based on admission webhooks and automatically configures DNSConfig for pods. If this function is disabled or the pods to be created are not in the target namespace, you must manually configure DNSConfig for the pods.
      After this function is enabled, you can customize the ConfigMaps below for DNSConfig (supported when the add-on version is 1.6.7 or later):
      In scenarios where DNSConfig is enabled, the DNS configuration specified within the pod overrides any injected DNSConfig settings.
      • (Optional) IP Address of DNS Server: an IP address list of the DNS server obtained when the container resolves the domain name. NodeLocal DNSCache and CoreDNS IP addresses are added by default. You have the option to add one extra IP address, but any duplicates will be removed.
      • (Optional) Search Domain: a search list for host-name lookup. When a domain name cannot be resolved, DNS queries will be attempted combining the domain name with each domain in the search list in turn until a match is found or all domains in the search list are tried. You can add up to three extra search domains, but any duplicates will be removed.
      • (Optional) ndots: specifies that if a domain name has fewer periods (.) than the specified value of ndots, it will be combined with the search domain list for DNS query. If the domain name still cannot be resolved, it will be used for DNS query. If the number of periods (.) in a domain name is greater than or equal to the value of ndots, the system will perform a DNS query on the domain name. If the domain name cannot be resolved, the system will sequentially combine it with the search domain list and then perform a DNS query.
    • Target Namespace: This parameter is available after DNSConfig is enabled. Only NodeLocal DNSCache of 1.3.0 or later supports this function.
      • Enable All: CCE adds the node-local-dns-injection=enabled label to all created namespaces excluding built-in ones and the ones preset by some add-ons (such as kube-system, kube-public, kube-node-lease, istio-system, and monitoring), identifies namespace creation requests, and automatically adds the label to newly created namespaces.
        In add-ons of 1.6.77 or later, the node-local-dns-injection=enabled label cannot be manually deleted. You can set node-local-dns-injection to disabled to disable automatic DNSConfig injection in a namespace.
      • Manually Configure: You must manually add the node-local-dns-injection=enabled label to the namespaces requiring DNSConfig injection. For details, see Managing Namespace Labels.
  5. Configure deployment policies for the add-on pods.
    • Scheduling policies do not take effect on the DaemonSet pods of the add-on.
    • When configuring multi-AZ deployment or node affinity, ensure that there are nodes meeting the scheduling policy and that resources are sufficient in the cluster. Otherwise, the add-on pods cannot run.
    Table 1 Configurations for add-on scheduling
    Multi-AZ Deployment
    • Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to different nodes in that AZ.
    • Equivalent mode: Deployment pods of the add-on are evenly scheduled to the nodes in the cluster in each AZ. If a new AZ is added, you are advised to increase add-on pods for cross-AZ HA deployment. With the Equivalent multi-AZ deployment, the difference between the number of add-on pods in different AZs will be less than or equal to 1. If resources in one of the AZs are insufficient, pods cannot be scheduled to that AZ.
    • Forcible: Deployment pods of the add-on are forcibly scheduled to nodes in different AZs. There can be at most one pod in each AZ. If nodes in a cluster are not in different AZs, some add-on pods cannot run properly. If a node is faulty, the add-on pods on it may fail to be migrated.
    Node Affinity
    • Not configured: Node affinity is disabled for the add-on pods.
    • Specify node: Specify the nodes where the add-on pods are deployed. If you do not specify the nodes, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
    • Specify node pool: Specify the node pool where the add-on pods are deployed. If you do not specify the node pools, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
    • Customize affinity: Enter the labels of the nodes where the add-on pods are to be deployed for more flexible scheduling policies. If you do not specify node labels, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
      If multiple custom affinity policies are configured, ensure that there are nodes that meet all the affinity policies in the cluster. Otherwise, the add-on pods cannot run.
    Toleration
    Using both taints and tolerations enables (but does not require) the add-on's Deployment pods to be scheduled on nodes with matching taints, and allows control over pod eviction policies when host nodes are tainted.
    The add-on applies default toleration policies for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints on pods. The tolerance time window is 60s.
    For details, see Configuring Tolerance Policies.
  6. Click Install.
Components
Table 2 Add-on components
Component
Resource Type
node-local-dns-admission-controller
Provide automatic DNSConfig injection.
Deployment
node-local-dns-cache
The DNS cache proxy on nodes to improve the DNS performance of the cluster
DaemonSet
Using NodeLocal DNSCache
By default, application requests are sent through the CoreDNS proxy. To use NodeLocal DNSCache as the DNS cache proxy, use either of the methods below. For details, see Using NodeLocal DNSCache.
  • Auto injection: Automatically configure the dnsConfig field of a pod during its creation. (This function is not available for pods in system namespaces such as kube-system.)
  • Manual configuration: Manually configure the dnsConfig field of a pod.
Changing the Default Health Check Port of the Add-on
NodeLocal DNSCache defaults to using port 8080 on the host node, but this can cause conflicts with other services sharing the same port. This section describes how to change the default NodeLocal DNSCache port.
You can change the default port of the NodeLocal DNSCache add-on of 1.6.66 or later.
  2. Choose Add-ons in the navigation pane, find the NodeLocal DNSCache add-on on the right, and click Install. If this add-on has been installed in the cluster, click Edit.
  3. On the displayed page, configure parameters and click Installation Using YAML in the upper part of the page. If this add-on has been installed in the cluster, click Edit YAML.
    To simplify configuration, configure other parameters on the console, and then change the port number in the YAML file. For more information about other parameters, see NodeLocal DNSCache.
  4. Configure both parameters to the specified port number, ensuring they have the same value.
    1. Search for the healthPort parameter and change its value to a specified port number, for example, 8081.
    2. Search for the cluster.local parameter and change the value of port in the array to the specified port number, for example, 8081.
  5. Click Submit.
Uninstalling the Add-on
Uninstalling the add-on will affect the pods that have used the node-local-dns address for domain name resolution. Before uninstalling the add-on, delete the node-local-dns-injection=enabled label from the involved namespaces, and delete and recreate the pods with the node-local-dns-webhook.k8s.io/status: injected label.
  1. Check the add-on.
    2. In the navigation pane, choose Add-ons. Locate NodeLocal DNSCache on the right and click Edit.
    3. In the Parameters area, check whether DNSConfig is enabled.
      If DNSConfig has been enabled:
      1. In the navigation pane, choose Namespaces.
      2. Locate the rows that contain the namespaces with the node-local-dns-injection=enabled label and delete the label. For details, see Managing Namespace Labels.
      3. Delete the pods in these namespaces and recreate pods.
      If DNSConfig has not been enabled:
      1. Use kubectl to access the cluster.
      2. Check the pods with DNSConfig manually injected. If multiple namespaces are involved, check all the pods in these namespaces.
        For example, to check pods in the default namespace, run the following command:
        kubectl get pod -n default -o yaml
      3. Manually remove DNSConfig and recreate pods.
  2. Uninstall the add-on.
    1. In the navigation pane, choose Add-ons. Locate NodeLocal DNSCache on the right and click Uninstall.
    2. In the displayed dialog box, click Yes.
Helpful Links
Release History
Table 3 NodeLocal DNSCache updates
Add-on Version
Supported Cluster Version
New Feature
Community Version
1.7.94
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Supported CCE clusters v1.36.
1.26.0
1.7.93
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Fixed some issues.
1.26.0
1.7.71
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Supported CCE clusters v1.35.
1.26.0
1.7.66
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Fixed some issues.
1.26.0
1.7.62
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Supported CCE clusters v1.34.
1.26.0
1.7.2
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Upgraded the community version to 1.26.0.
1.26.0
1.6.88
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Supported CCE clusters v1.33.
1.22.20
1.6.80
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
Supported CCE clusters v1.32.
1.22.20
1.6.66
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
The health check port can be changed.
1.22.20
1.6.62
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Supported CCE clusters v1.31.
1.22.20
1.6.37
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
The admission-controller logs have been updated to standard output logs.
1.22.20
1.6.36
v1.23
v1.25
v1.27
v1.28
v1.29
v1.30
Supported CCE clusters v1.30.
1.22.20
1.6.8
v1.23
v1.25
v1.27
v1.28
v1.29
Optimized custom injection configuration experience.
1.22.20
1.6.7
v1.23
v1.25
v1.27
v1.28
v1.29
Added custom injection configurations.
1.22.20
1.6.2
v1.21
v1.23
v1.25
v1.27
v1.28
v1.29
Supported CCE clusters v1.29.
1.22.20
1.5.2
v1.21
v1.23
v1.25
v1.27
v1.28
Fixed some issues.
1.22.20
1.5.1
v1.21
v1.23
v1.25
v1.27
v1.28
Fixed some issues.
1.22.20
1.5.0
v1.21
v1.23
v1.25
v1.27
v1.28
  • Supported CCE clusters v1.28.
  • Supported equivalent distribution of add-on pods in multi-AZ deployment mode.
  • Changed the base image OS of the add-on pods to Huawei Cloud EulerOS 2.0.
1.22.20
1.4.0
v1.19
v1.21
v1.23
v1.25
v1.27
Resolved the issue that CCI pods took an excessively long time to access the Internet.
1.22.20
1.2.7
v1.19
v1.21
v1.23
v1.25
Supported anti-affinity scheduling of add-on pods on nodes in different AZs.
1.21.1
1.2.4
v1.19
v1.21
v1.23
v1.25
Supported CCE clusters v1.25.
1.21.1
1.2.2
v1.19
v1.21
v1.23
Supported custom NodeLocal DNSCache specifications.
1.21.1
