Help Center/ Cloud Container Engine/ User Guide/ Storage/ OBS/ Using an Existing OBS Bucket Through a Static PV
Updated on 2026-06-16 GMT+08:00
This section describes how to use an existing Object Storage Service (OBS) bucket to statically create PVs and PVCs for data persistence and sharing in workloads.
  • If OBS volumes are used, the owner group and permission of the mount point cannot be modified.
  • Every time an OBS volume is mounted to a workload through a PVC, a resident process is created in the backend. When a workload uses too many OBS volumes or reads and writes a large number of object storage files, resident processes will consume a significant amount of memory. To ensure stable running of the workload, make sure that the number of OBS volumes used does not exceed the requested memory. For example, if the workload requests 4 GiB of memory, the number of OBS volumes should be no more than 4.
  • Secure containers do not support OBS volumes.
  • Hard links are not supported when common buckets are mounted.
  • Read-only is not supported when an OBS PVC is mounted to a workload.
  • Multiple PVs can use the same OBS storage volume with the following restrictions:
    • Do not mount multiple PVCs or PVs that use the same underlying OBS volume to a single pod. Doing so will cause pod startup failures, as not all PVCs can be mounted due to identical volumeHandle value.
    • The persistentVolumeReclaimPolicy parameter in the PVs must be set to Retain. Otherwise, when a PV is deleted, the associated underlying volume may be deleted. In this case, other PVs associated with the underlying volume malfunction.
    • If underlying storage is repeatedly used, you are required to maintain data consistency. Enable application-layer isolation and protection for ReadWriteMany to prevent multiple clients from writing to the same file, thereby avoiding data overwriting and loss.
CCE allows you to create PVs and PVCs using existing OBS buckets and mount the PVCs to workloads using the console or kubectl.
  2. Statically create a PVC and PV.
    1. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Click Create PVC in the upper right corner. On the slide-out panel, configure PVC parameters.
      PVC Type
      In this example, select OBS.
      PVC Name
      Enter the PVC name, which must be unique in a namespace.
      Creation Method
      • If the underlying storage is available, create a PV or use an existing PV to statically create a PVC.
      • If no underlying storage is available, select Dynamically provision. For details, see Using an OBS Bucket Through a Dynamic PV.
      In this example, select Create new to create both a PV and PVC on the console.
      PVa
      Select an existing PV in the cluster. For details about how to create a PV, see "Creating a storage volume" in Related Operations.
      You do not need to specify this parameter in this example.
      OBSb
      Click Select OBS. On the displayed page, select the OBS volume that meets your requirements and click OK.
      PV Nameb
      Enter the PV name, which must be unique in the same cluster.
      Access Modeb
      OBS volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple nodes in read/write mode. For details, see Volume Access Modes.
      Reclaim Policyb
      You can select Delete or Retain to specify the reclaim policy of the underlying storage when the PVC is deleted. For details, see PV Reclaim Policy.
      If multiple PVs use the same OBS volume, use Retain to prevent the underlying volume from being deleted with a PV.
      Access Key (AK/SK)b
      • Custom access keys: Different IAM users use their own access keys (AK/SK). You can use IAM to control the permissions of IAM users to access OBS. (This method is recommended.) For details, see Using a Custom Access Key (AK/SK) to Mount an OBS Volume.
        Only secrets with the secret.kubernetes.io/used-by = csi label can be selected. The secret type is cfe/secure-opaque. If no secret is available, click Create Secret to create one.
        • Name: Enter a secret name.
        • Namespace: Select the namespace where the secret is.
        • Access Key (AK/SK)
      • Global access secret (paas.longaksk): All clusters use the AK/SK of the account. This method is simple, but fine-grained access permission control cannot be implemented. If you have created a global access secret while using OBS volumes in a cluster, the system will create a secret called paas.longaksk in the kube-system namespace of the cluster. This secret is used to store the global AK/SK. The global access secret (paas.longaksk) is used by project. Once a global access secret is used, it is automatically created for each cluster within the same project. You can disable the global access secret in Settings > Cluster Settings.
        If the cluster does not use the global access secret, this option is not displayed.
      • Global agency: The agency configured by the container storage add-on is used to control OBS permissions. For details, see Using an Agency to Mount an OBS Volume.
      • Workload agency: Before using a workload agency, associate the workload's ServiceAccount with the IAM agency and grant the agency OBS read/write permissions. For details, see Using Pod Identities to Obtain IAM Credentials in a CCE Cluster.
      CAUTION:
      If the AK/SK is deleted or disabled accidentally, the container cannot use the OBS volume.
      Mount Optionsb
      Enter the mounting parameter key-value pairs. For details, see Configuring OBS Mount Options.
      a: The parameter is available when Creation Method is set to Use existing.
      b: The parameter is available when Creation Method is set to Create new.
    2. Click Create to create a PVC and a PV.
      You can choose Storage in the navigation pane and view the created PVC and PV on the PVCs and PVs tabs, respectively.
  3. Create an application.
    1. Choose Workloads in the navigation pane. In the right pane, click the Deployments tab.
    2. Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Information area under Container Settings and choose Add Volume > PVC.
      Mount and use storage volumes. For details about the parameters, see Table 1. For other parameters, see Workloads.
      Table 1 Mounting a storage volume
      PVC
      Select an existing OBS volume.
      Mount Path
      Enter a mount path, for example, /tmp.
      This parameter specifies a container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. This may lead to container errors. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, leading to container startup failures or workload creation failures.
      NOTICE:
      If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host may be damaged.
      Subpath
      Enter the subpath of the storage volume and mount a path in the storage volume to the container. In this way, different folders of the same storage volume can be used in a single pod. tmp, for example, indicates that data in the mount path of the container is stored in the tmp folder of the storage volume. If this parameter is left blank, the root path will be used by default.
      Permission
      • Read-only: You can only read the data in the mounted volumes.
      • Read-write: You can modify the data volumes mounted to the path. Newly written data will not be migrated if the container is migrated, which may cause data loss.
      In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the OBS volume.
    3. After the configuration, click Create Workload.
      After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence and Sharing.
  1. Use kubectl to access the cluster.
  2. Create a PV.
    1. Create the pv-obs.yaml file.
      apiVersion: v1
      kind: PersistentVolume
        annotations:
          pv.kubernetes.io/provisioned-by: everest-csi-provisioner
          everest.io/reclaim-policy: retain-volume-only      # (Optional) The underlying volume is retained when the PV is deleted.
        name: pv-obs       # PV name
        accessModes:
        - ReadWriteMany    # Access mode. The value must be ReadWriteMany for OBS volumes.
        capacity:
          storage: 1Gi     # Storage capacity. This parameter is only for verification. It must not be empty or 0, but the specified size will not take effect.
        csi:
          driver: obs.csi.everest.io        # Dependent storage driver for the mounting
          fsType: obsfs                     # Instance type
          volumeHandle: <your_volume_id>    # Name of the OBS volume
          volumeAttributes:
            storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
            everest.io/obs-volume-type: STANDARD
            everest.io/region: <your_region>                        # Region where the OBS volume is
            everest.io/enterprise-project-id: <your_enterprise_project_id>     # (Optional) Enterprise project ID. If an enterprise project is specified, you must specify the same enterprise project when creating a PVC. Otherwise, the PVC cannot bind to a PV.
          nodePublishSecretRef:            # Custom secret of the OBS volume
            name: <your_secret_name>       # Custom secret name
            namespace: <your_namespace>    # Namespace of the custom secret
        persistentVolumeReclaimPolicy: Retain    # Reclaim policy
        storageClassName: csi-obs               # StorageClass name
        mountOptions: []                         # Mount options
      Table 2 Key parameters
      Mandatory
      No
      Optional.
      Only retain-volume-only is supported.
      This parameter is valid only when the Everest version is 1.2.9 or later and the reclaim policy is Delete. If the reclaim policy is Delete and the current value is retain-volume-only, the associated PV is deleted while the underlying storage volume is retained, when a PVC is deleted.
      fsType
      Yes
      Instance type. The value can be obsfs or s3fs.
      • obsfs: a parallel file system
      • s3fs: an object bucket
      volumeHandle
      Yes
      OBS volume name.
      Yes
      OBS StorageClass.
      • If fsType is set to s3fs, standard buckets (STANDARD) and infrequent access buckets (WARM) are supported.
      • This parameter is invalid when fsType is set to obsfs.
      everest.io/region
      Yes
      Region where the OBS bucket is deployed.
      For details about its value, see Regions and Endpoints.
      No
      This parameter specifies the ID of the enterprise project where an OBS volume is created. It is applicable only to enterprise accounts with enterprise projects enabled. For more details, see Enterprise Center Overview.
      How to obtain: On the OBS console, choose Buckets or Parallel File Systems in the navigation pane. Click the name of the OBS bucket to access its details page. In the Basic Information area, locate the enterprise project and click it to access the enterprise project console. Copy the corresponding ID to obtain the ID of the enterprise project to which the object storage belongs.
      No
      Access key (AK/SK) used for mounting the object storage volume. You can use the AK/SK to create a secret and mount it to the PV. For details, see Using a Custom Access Key (AK/SK) to Mount an OBS Volume.
      Example:
        namespace: default
      mountOptions
      No
      Mount options. For details, see Configuring OBS Mount Options.
      Yes
      A reclaim policy is supported when the cluster version is or later than 1.19.10 and the Everest version is or later than 1.2.9.
      The Delete and Retain reclaim policies are supported. For details, see PV Reclaim Policy. If multiple PVs use the same OBS volume, use Retain to prevent the underlying volume from being deleted with a PV.
      Delete:
      • If everest.io/reclaim-policy is not specified, both the PV and storage resources will be deleted when a PVC is deleted.
      • If everest.io/reclaim-policy is set to retain-volume-only, when a PVC is deleted, the PV will be deleted but the storage resources will be retained.
      Retain: When a PVC is deleted, both the PV and underlying storage resources will be retained. You need to manually delete these resources. After the PVC is deleted, the PV is in the Released state and cannot be bound to a PVC again. If you want to continue using the underlying storage resources, delete the PV first. Then, create a new PV and PVC and associate them with the underlying storage resources.
      storage
      Yes
      Storage capacity, in Gi.
      For OBS, this parameter is only for verification. It must not be empty or 0, and its value is fixed at 1. Any value you set will not take effect.
      storageClassName
      Yes
      StorageClass name, which is csi-obs for an OBS volume.
    2. Run the following command to create a PV:
      kubectl apply -f pv-obs.yaml
  3. Create a PVC.
    1. Create the pvc-obs.yaml file.
      apiVersion: v1
      kind: PersistentVolumeClaim
        namespace: default
        annotations:
          volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner
          csi.storage.k8s.io/fstype: obsfs
          csi.storage.k8s.io/node-publish-secret-name: <your_secret_name>  # Custom secret name
          csi.storage.k8s.io/node-publish-secret-namespace: <your_namespace>        # Namespace of the custom secret
          everest.io/enterprise-project-id: <your_enterprise_project_id>     # (Optional) Enterprise project ID. If an enterprise project is specified during PV creation, you must specify the same enterprise project when creating a PVC. Otherwise, the PVC cannot be bound to the PV.
        accessModes:
        - ReadWriteMany                  # The value must be ReadWriteMany for OBS volumes.
        resources:
          requests:
            storage: 1Gi
        storageClassName: csi-obs       # StorageClass name, which must be the same as that of the PV
        volumeName: pv-obs    # PV name
      Table 3 Key parameters
      Mandatory
      No
      Name of the custom secret specified in the PV.
      No
      Namespace of the custom secret specified in the PV.
      No
      storage
      Yes
      Requested capacity in the PVC, in Gi.
      storageClassName
      Yes
      StorageClass name, which must be the same as the StorageClass of the PV in 1.
      volumeName
      Yes
      PV name, which must be the same as the PV name in 1.
    2. Run the following command to create a PVC:
      kubectl apply -f pvc-obs.yaml
  4. Create an application.
    1. Create a file named web-demo.yaml. In this example, the OBS volume is mounted to the /data path.
      apiVersion: apps/v1
      kind: Deployment
        namespace: default
        replicas: 2
        selector:
          matchLabels:
            app: web-demo
        template:
            labels:
              app: web-demo
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
              - name: pvc-obs-volume    # Volume name, which must be the same as the volume name in the volumes field
                mountPath: /data  # Location where the storage volume is mounted
            imagePullSecrets:
              - name: default-secret
            volumes:
              - name: pvc-obs-volume    # Volume name, which is user-defined
                persistentVolumeClaim:
                  claimName: pvc-obs    # Name of the created PVC
    2. Run the following command to create a workload to which the OBS volume is mounted:
      kubectl apply -f web-demo.yaml
      After the workload is created, you can try Verifying Data Persistence and Sharing.
  1. View the deployed application and files.
    1. Run the following command to view the created pod:
      kubectl get pod -n <namespace> | grep web-demo
      Expected output:
      web-demo-846b489584-mjhm9   1/1     Running   0             46s
      web-demo-846b489584-wvv5s   1/1     Running   0             46s
    2. Run the following commands in sequence to check the files in the /data path of the pods:
      kubectl exec -n <namespace> web-demo-846b489584-mjhm9 -- ls /data
      kubectl exec -n <namespace> web-demo-846b489584-wvv5s -- ls /data
      If no result is returned for both pods, no file exists in the /data path.
  2. Run the following command to create a file named static in the /data path:
    kubectl exec -n <namespace> web-demo-846b489584-mjhm9 --  touch /data/static
  3. Run the following command to check the files in the /data path:
    Expected output:
    static
  4. Verify data persistence.
    1. Run the following command to delete the pod named web-demo-846b489584-mjhm9:
      kubectl delete pod -n <namespace> web-demo-846b489584-mjhm9
      Expected output:
      pod "web-demo-846b489584-mjhm9" deleted
      After the deletion, the Deployment controller automatically creates a replica.
    2. Run the following command to view the created pod:
      The expected output is as follows, in which web-demo-846b489584-d4d4j is the newly created pod:
      web-demo-846b489584-d4d4j   1/1     Running   0             110s
      web-demo-846b489584-wvv5s    1/1     Running   0             7m50s
    3. Run the following command to check whether the files in the /data path of the new pod have been modified:
      kubectl exec -n <namespace> web-demo-846b489584-d4d4j -- ls /data
      Expected output:
      static
      The static file is retained, indicating that the data can be stored persistently.
  5. Verify data sharing.
      Expected output:
      web-demo-846b489584-d4d4j   1/1     Running   0             7m
      web-demo-846b489584-wvv5s   1/1     Running   0             13m
    2. Run the command below to create a file named share in the /data path of either pod. In this example, select the pod named web-demo-846b489584-d4d4j.
      kubectl exec -n <namespace> web-demo-846b489584-d4d4j --  touch /data/share
      Check the files in the /data path of the pod.
      Expected output:
      share
      static
    3. Check whether the share file exists in the /data path of another pod (web-demo-846b489584-wvv5s) as well to verify data sharing.
      Expected output:
      share
      static
      After you create a file in the /data path of a pod, if the file is also created in the /data path of the other pod, the two pods share the same volume.
Related Operations
You can also perform the operations listed in Table 4.
Table 4 Related operations
Operation
Creating a storage volume (PV)
Create a PV on the CCE console.
  1. Choose Storage in the navigation pane. In the right pane, click the PVs tab. Click Create PV in the upper right corner. On the slide-out panel, configure parameters.
    • Volume Type: Select OBS.
    • OBS: Click Select OBS. On the displayed page, select the OBS volume that meets your requirements and click OK.
    • PV Name: Enter the PV name, which must be unique in a cluster.
    • Access Mode: SFS volumes support only ReadWriteMany, indicating that a storage volume can be mounted to multiple nodes in read/write mode. For details, see Volume Access Modes.
    • Reclaim Policy: Delete or Retain is supported. For details, see PV Reclaim Policy.
      If multiple PVs use the same underlying storage volume, use Retain to prevent the underlying volume from being deleted with a PV.
    • AK/SK: (Recommended) Select Custom if you want to assign different user permissions to different OBS storage devices. For details, see Using a Custom Access Key (AK/SK) to Mount an OBS Volume.
    • Mount Options: Enter the mounting parameter key-value pairs. For details, see Configuring OBS Mount Options.
  2. Click Create.
Updating an access key
Update the access key of object storage on the CCE console.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs tab. Locate the target PVC and choose More > Update Access Key in the Operation column.
  2. Upload a key file in .csv format. For details, see Obtaining Access Keys. Click OK.
    After a global access key is updated, all pods mounted with the object storage that uses this access key can be accessed only after being restarted.
Viewing events
View event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. Choose Storage in the navigation pane. In the right pane, click the PVCs or PVs tab.
  2. Locate the target PVC or PV and click View Events in the Operation column to view events generated within one hour (events are retained for one hour).
Viewing a YAML file
View, copy, or download the YAML file of a PVC or PV.
  2. Locate the target PVC or PV and click View YAML in the Operation column to view, copy, or download the YAML.
Editing Reclaim Policy
Modify the reclaim policy of a PV.
  2. Locate the target PV and choose More > Edit Reclaim Policy in the Operation column.
