Changing the Billing Mode of a Cluster from Pay-per-Use to Yearly/Monthly
A cluster can be billed on a pay-per-use or yearly/monthly basis. The billing mode of a cluster can be changed from pay-per-use to yearly/monthly.
To change the billing mode of a node from pay-per-use to yearly/monthly, see Changing the Billing Mode of a Node to Yearly/Monthly.
To change the billing mode of a cluster from pay-per-use to yearly/monthly, perform the following operations:
- Log in to the CCE console. In the navigation pane, choose Clusters.
- Locate the target cluster, click ... to view more operations on the cluster, and choose Change Billing Mode.
- On the page displayed, select the target cluster and click OK. You can also select the nodes whose billing modes you want to change. Figure 1 Changing the billing mode of a cluster to yearly/monthly
- Wait for the resource checks and the order generation, click OK to go to the Billing Center, and submit the order. Figure 2 Generating an order
- Select the resources whose billing modes are to be changed to yearly/monthly, set the required duration, enable auto-renew, and click Pay. Figure 3 Changing the billing mode from pay-per-use to yearly/monthly
Helpful Links
