(kubectl) Creating a PV from an Existing SFS Turbo File System
CCE allows you to use an existing SFS Turbo file system to create a PersistentVolume (PV). After the creation is successful, you can create a PersistentVolumeClaim (PVC) and bind it to the PV.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
- Log in to the SFS console, create a file system, and record the file system ID, shared path, and capacity.
- Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
- Create two YAML files for creating the PV and PVC. Assume that the file names are pv-efs-example.yaml and pvc-efs-example.yaml.
touch pv-efs-example.yaml pvc-efs-example.yaml
- Example YAML file for the PV:
apiVersion: v1 kind: PersistentVolume metadata: name: pv-efs-example annotations: pv.kubernetes.io/provisioned-by: flexvolume-huawei.com/fuxiefs spec: accessModes: - ReadWriteMany capacity: storage: 100Gi claimRef: apiVersion: v1 kind: PersistentVolumeClaim name: pvc-efs-example namespace: default flexVolume: driver: huawei.com/fuxiefs fsType: efs options: deviceMountPath: <your_deviceMountPath> # Shared storage path of your SFS Turbo file. fsType: efs volumeID: 8962a2a2-a583-4b7f-bb74-fe76712d8414 persistentVolumeReclaimPolicy: Delete storageClassName: efs-standardTable 1 Key parameters Parameter
driver
Storage driver used to mount the volume. Set it to huawei.com/fuxiefs.
deviceMountPath
Shared path of the SFS Turbo volume.
volumeID
SFS Turbo volume ID.
To obtain the ID, log in to the CCE console, choose Resource Management > Storage, click the PVC name in the SFS Turbo tab page, and copy the PVC ID on the PVC details page.
storage
File system size.
storageClassName
Volume type supported by SFS Turbo. The value can be efs-standard and efs-performance. Currently, SFS Turbo does not support dynamic creation; therefore, this parameter is not used for now.
spec.claimRef.apiVersion
The value is fixed at v1.
spec.claimRef.kind
The value is fixed at PersistentVolumeClaim.
spec.claimRef.name
The value is the same as the name of the PVC created in the next step.
spec.claimRef.namespace
The value is the same as the namespace of the PVC created in the next step.
- Example YAML file for the PVC:
apiVersion: v1 kind: PersistentVolumeClaim metadata: annotations: volume.beta.kubernetes.io/storage-class: efs-standard volume.beta.kubernetes.io/storage-provisioner: flexvolume-huawei.com/fuxiefs name: pvc-efs-example namespace: default spec: accessModes: - ReadWriteMany resources: requests: storage: 100Gi volumeName: pv-efs-exampleTable 2 Key parameters Parameter
Read/write mode supported by SFS Turbo. The value can be efs-standard or efs-performance. The value must be the same as that of the existing PV.
The field must be set to flexvolume-huawei.com/fuxiefs.
storage
Storage capacity, in the unit of Gi. The value must be the same as the storage size of the existing PV.
volumeName
Name of the PV.
The VPC to which the SFS Turbo file system belongs must be the same as the VPC of the ECS VM planned for the workload. Ports 111, 445, 2049, 2051, and 20048 must be enabled in the security groups.
- Create the PV.
kubectl create -f pv-efs-example.yaml
- Create the PVC.
kubectl create -f pvc-efs-example.yaml
