Updated on 2025-04-27 GMT+08:00
(kubectl) Creating a StatefulSet Mounted with an OBS Volume
CCE allows you to use an existing OBS volume to create a StatefulSet through a PersistentVolumeClaim (PVC).
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Create an OBS volume by referring to Automatically Creating an OBS Volume Through kubectl and obtain the PVC name.
  2. Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  3. Create a YAML file for creating the workload. Assume that the file name is obs-statefulset-example.yaml.
    touch obs-statefulset-example.yaml
    vi obs-statefulset-example.yaml
    Example YAML:
    apiVersion: apps/v1
    kind: StatefulSet
      namespace: default
      replicas: 1
      selector:
        matchLabels:
          app: obs-statefulset-example
      serviceName: qwqq
      template:
          annotations:
            metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]'
            pod.alpha.kubernetes.io/initialized: "true"
          creationTimestamp: null
          labels:
          affinity: {}
          containers:
            image: nginx:latest
            imagePullPolicy: Always
            volumeMounts:
            - mountPath: /tmp
          imagePullSecrets:
          - name: default-secret
          volumes:
            - name: pvc-obs-example
              persistentVolumeClaim:
                claimName: cce-obs-demo
    Table 1 Key parameters
    replicas
    Number of pods.
    name
    Name of the created workload.
    Image used by the workload.
    mountPath
    Mount path in the container.
    serviceName
    Service corresponding to the workload. For details about how to create a Service, see Creating a StatefulSet.
    claimName
    Name of an existing PVC.
  4. Create the StatefulSet.
    kubectl create -f obs-statefulset-example.yaml
