Updated on 2026-09-21 GMT+08:00
(kubectl) Creating a Deployment Mounted with an SFS Volume
After an SFS volume is created or imported to CCE, you can mount the volume to a workload.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Run the following commands to configure the sfs-deployment-example.yaml file, which is used to create a pod.
    touch sfs-deployment-example.yaml
    vi sfs-deployment-example.yaml
    Example of mounting an SFS volume to a Deployment (PVC-based, shared volume):
    apiVersion: apps/v1
    kind: Deployment
      name: sfs-deployment-example                                # Workload name
      namespace: default
      replicas: 1
      selector:
        matchLabels:
          app: sfs-deployment-example
      template:
          labels:
          containers:
          - image: nginx
            volumeMounts:
            - mountPath: /tmp                                # Mount path
          imagePullSecrets:
            - name: default-secret
          restartPolicy: Always
          volumes:
          - name: pvc-sfs-example
            persistentVolumeClaim:
              claimName: pvc-sfs-auto-example                # PVC name
    Table 1 Key parameters
    Parent Parameter
    metadata
    name
    Name of the pod to be created.
    spec.template.spec.containers.volumeMounts
    mountPath
    Mount path in the container. In this example, the mount path is /tmp.
    spec.template.spec.volumes.persistentVolumeClaim
    claimName
    Name of an existing PVC.
    spec.template.spec.containers.volumeMounts.name and spec.template.spec.volumes.name must be consistent because they have a mapping relationship.
    Example of mounting an SFS volume to a StatefulSet (PVC template-based, dedicated volume):
    Currently, SFS file systems are sold out and cannot be exclusively used by defining the PVC template.
    Example YAML:
    apiVersion: apps/v1
    kind: StatefulSet
      namespace: default
      labels:
        appgroup: ''
      replicas: 2
      selector:
        matchLabels:
          app: deploy-sfs-nfs-rw-in
      template:
          labels:
          containers:
            - name: container-0
              image: 'nginx:1.12-alpine-perl'
              volumeMounts:
                - name: bs-nfs-rw-mountoptionpvc
                  mountPath: /aaa
          imagePullSecrets:
      volumeClaimTemplates:
        - metadata:
            annotations:
              volume.beta.kubernetes.io/storage-class: nfs-rw
              volume.beta.kubernetes.io/storage-provisioner: flexvolume-huawei.com/fuxinfs
            accessModes:
              - ReadWriteMany
            resources:
              requests:
                storage: 1Gi
      serviceName: wwww
    Table 2 Key parameters
    Parent Parameter
    metadata
    name
    Name of the created workload.
    Image of the workload.
    mountPath
    spec
    serviceName
    Service corresponding to the workload. For details about how to create a Service, see Creating a StatefulSet.
    spec.template.spec.containers.volumeMounts.name and spec.volumeClaimTemplates.metadata.name must be consistent because they have a mapping relationship.
  3. Run the following command to create the pod:
    kubectl create -f sfs-deployment-example.yaml
    After the creation is complete, log in to the CCE console. In the navigation pane, choose Resource Management > Storage > SFS. Click the PVC name. On the PVC details page, you can view the binding relationship between SFS and PVC.
