Updated on 2025-11-06 GMT+08:00
Renewing a Yearly/Monthly Cluster
If a yearly/monthly cluster is not renewed after expiration, CCE will delete it. After the cluster is deleted, the nodes and running services within the cluster will be terminated. Renew the subscription before expiration to continue using the cluster. This section describes how to renew a yearly/monthly cluster. In addition to the method described in this section, you can enable auto-renewal. For details, see Enabling Auto-Renewal.
  1. Log in to the CCE console. In the navigation pane, choose Clusters.
  2. Locate the cluster to be renewed, click ... to view more operations on the cluster, and choose Renew.
    Figure 1 Renewing a cluster
  3. On the displayed page, renew the cluster as prompted.
    • If the selected resource (highlighted) is associated with other resources, you can decide whether you want to perform the operation on all these resources at the same time.
    • If you change the resource specifications before its renewal period takes effect, the renewal period cannot be unsubscribed from.
  4. Click Pay. On the page displayed, review the order amount, select a payment method, and click Pay.
  5. Go back to the Orders or Renewals page to view and manage your order.
