Updated on 2025-11-03 GMT+08:00
Deleting a Backup
You can delete unwanted backups to reduce space usage and costs.
If a backup has been used to create an image, the backup cannot be deleted. In this case, delete the image first based on the instructions in Deleting Images.
CBR supports manual deletion of backups and automatic deletion of expired backups. The latter is executed based on the backup retention rule in the backup policy. For details, see Creating a Backup Policy.
  • Backups are not stored on a server. Deleting backups has no impact on the server performance.
  • If a backup has been created and the next backup task is in progress, CBR will not allow you to delete the most recent backup. You can delete the backup only after the backup task is complete.
  • CBR automatically creates snapshots during backup and retains the latest snapshot for each disk. If a disk already has a backup, after another backup, the old snapshot will be deleted and the latest one will be retained.
  • There is at least one backup.
  • The backups to be deleted are in the Available or Error state.
Billing
  • You are billed for the storage space and the data traffic generated if backup replication is used. Pricing of the storage space varies with vault types. The vault capacity remains unchanged after backups are deleted, so the charges remain unchanged.
  • For details about billed items, see CBR Billing. For details about pricing, see CBR pricing details.
  1. Log in to the CBR console.
    2. In the upper left corner, click and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery. Select the corresponding backup type from the navigation pane.
  2. Click the Backups tab. Locate the desired backup. For details, see Viewing a Backup.
  3. Choose More > Delete from the Operation column. Alternatively, select the backups you want to delete in a batch and click Delete in the upper left corner to delete them.
    Figure 1 Deleting a backup
  4. Click OK. Return to the backup list. If the target backup does not exist, the backup is deleted successfully.
Documents
