Help Center/ Cloud Application Engine/ User Guide/ System Settings/ Configuring Start/Stop Policies
Updated on 2025-10-22 GMT+08:00
  • You can configure up to 20 start/stop policies.
  • Do not start or stop a component when it is being scaled. Disable the AS policy before the operation.
  • When a component is being started, restarted, or stopped, AS policies cannot be added or enabled for the component.
Adding a Start/Stop Policy
  1. Log in to CAE.
  2. Choose System Settings.
  3. Click Edit in the Start/Stop Policy Configuration module.
  4. Click Add Policy. Configure the start/stop policy by referring to the following table.
    Policy Name
    Enter a policy name.
    The policy name must be unique.
    Effected Components
    • All in the environment: The start/stop policy takes effect for all components in the environment.
    • All in the application: The start/stop policy takes effect for all components in the selected application.
      • Start/stop policies do not take effect for components in the Not deployed state.
      • For components in the Deploying state, start/stop policies will fail to be executed. For details about the failure cause, see Viewing a Start/Stop Policy.
      • All in the environment and All in the application policies also take effect for newly added components.
    • Some: The start/stop policy takes effect for the selected components.
      Components in the Not deployed state cannot be selected.
    Status
    • Enable: The start/stop policy is enabled and will be triggered at the specified time.
    • Disabled: The start/stop policy is disabled.
    Policy
    • Start: After the policy is configured, components will be started in batches. Components that have been started are not affected.
    • Stop: After the policy is configured, components will be stopped in batches. Components that have been stopped are not affected.
    Trigger
    • Once: The policy is triggered only once. After the policy is triggered, Status will be disabled.
    • Periodically: The policy is executed periodically. Currently, the policy can be executed by week or day.
    Triggered
    • Select a time when Trigger is set to Once.
    • When Trigger is set to Periodically:
      Every week: Select a date and time for triggering the policy every week. For example, 17:30 on every Monday.
      Every day: Select a time for triggering the policy every day. For example, 01:00 every day.
      Triggered time must be at least two minutes after the current time.
  5. Click OK.
Editing a Start/Stop Policy
  1. Log in to CAE.
  4. Select the target policy and click Edit in the Operation column. Reconfigure the policy by referring the following table.
    Policy Name
    Effected Components
    Status
    Policy
    Trigger
    Triggered
  5. Click OK.
Deleting a Start/Stop Policy
  1. Log in to CAE.
  4. Select the target policy and click Delete in the Operation column.
  5. If Deleted is displayed, the policy is deleted.
Searching for a Start/Stop Policy
  1. Log in to CAE.
  4. In the search box in the upper right corner, enter a policy name (fuzzy search is supported).
  5. Click to filter the start/stop policy.
Policies in the Not executed and Executing states cannot be viewed.
  1. Log in to CAE.
  4. Select the target policy and click Execution Details in the Operation column.
  5. View the execution status of the start/stop policy.
