Configuring Start/Stop Policies
- You can configure up to 20 start/stop policies.
- Do not start or stop a component when it is being scaled. Disable the AS policy before the operation.
- When a component is being started, restarted, or stopped, AS policies cannot be added or enabled for the component.
Adding a Start/Stop Policy
- Log in to CAE.
- Choose System Settings.
- Click Edit in the Start/Stop Policy Configuration module.
- Click Add Policy. Configure the start/stop policy by referring to the following table.
Policy Name
Enter a policy name.
The policy name must be unique.
Effected Components
- All in the environment: The start/stop policy takes effect for all components in the environment.
- All in the application: The start/stop policy takes effect for all components in the selected application. NOTE:
- Start/stop policies do not take effect for components in the Not deployed state.
- For components in the Deploying state, start/stop policies will fail to be executed. For details about the failure cause, see Viewing a Start/Stop Policy.
- All in the environment and All in the application policies also take effect for newly added components.
- Some: The start/stop policy takes effect for the selected components. NOTE:
Components in the Not deployed state cannot be selected.
Status
- Enable: The start/stop policy is enabled and will be triggered at the specified time.
- Disabled: The start/stop policy is disabled.
Policy
- Start: After the policy is configured, components will be started in batches. Components that have been started are not affected.
- Stop: After the policy is configured, components will be stopped in batches. Components that have been stopped are not affected.
Trigger
- Once: The policy is triggered only once. After the policy is triggered, Status will be disabled.
- Periodically: The policy is executed periodically. Currently, the policy can be executed by week or day.
Triggered
- Select a time when Trigger is set to Once.
- When Trigger is set to Periodically:
Every week: Select a date and time for triggering the policy every week. For example, 17:30 on every Monday.
Every day: Select a time for triggering the policy every day. For example, 01:00 every day.
NOTE:Triggered time must be at least two minutes after the current time.
- Click OK.
Editing a Start/Stop Policy
- Log in to CAE.
- Select the target policy and click Edit in the Operation column. Reconfigure the policy by referring the following table.
Policy Name
Effected Components
Status
Policy
Trigger
Triggered
- Click OK.
Deleting a Start/Stop Policy
- Log in to CAE.
- Select the target policy and click Delete in the Operation column.
- If Deleted is displayed, the policy is deleted.
Searching for a Start/Stop Policy
- Log in to CAE.
- In the search box in the upper right corner, enter a policy name (fuzzy search is supported).
- Click
to filter the start/stop policy.
Policies in the Not executed and Executing states cannot be viewed.
- Log in to CAE.
- Select the target policy and click Execution Details in the Operation column.
- View the execution status of the start/stop policy.
