Help Center/
Cloud Application Engine/
User Guide/
Component Configurations/
Configuring an AS Policy/
Disabling an AS Policy
Updated on 2025-10-22 GMT+08:00
Disable an AS policy that is no longer needed. After the AS policy is disabled, instances will not be automatically scaled.
Disable the AS policy before stopping a component or configuring manual scaling.
- Log in to CAE.
- Choose Component Configurations.
- Select the target component from the component drop-down list in the upper part of the page.
- Click Edit in the AS Policies module.
- Click
to disable the AS policy and click OK. - Click Activate Settings in the upper part of the page. In the dialog box displayed on the right, confirm the configurations and click OK for the configurations to take effect.
Parent topic: Configuring an AS Policy
