Updated on 2025-09-15 GMT+08:00
Configuring Certificates
You can bind up to 10 certificates.
Adding a Certificate
- Log in to CAE.
- Choose System Settings.
- Click Edit in the Certificates module.
- Click Add Certificate.
- Enter a certificate name For example, test-1.
- Upload Server Certificate Content and Server Private Key Content.
- Click OK.
Editing a Certificate
- Log in to CAE.
- Select the target certificate and click Edit in the Operation column.
- Edit Server Certificate Content and Server Private Key Content.
Figure 1 Editing a certificate
- Click OK.
Deleting a Certificate
- Log in to CAE.
- Select the target certificate and click Delete in the Operation column.
- If Deleted is displayed, the certificate is deleted.
If Failed to unbind xx is displayed when you delete a certificate, choose Component Configurations > Access Mode > Forwarding Policy to check whether the certificate is in use.
Parent topic: System Settings
