Updated on 2025-11-13 GMT+08:00
Manually Scaling Component Instances
The number of instances will be increased or decreased immediately after the configuration is complete.
Ensure that no AS policy is enabled. Disable the AS policy before configuring manual scaling. For details, see Disabling an AS Policy.
  1. Log in to CAE.
  2. Choose Components.
  3. Mouse over the target component instance and click the displayed .
    Figure 1 Configuring manual scaling
  4. Enter the target number of instances, which ranges from 1 to 99.
  5. Click OK.
