Help Center/ Cloud Application Engine/ User Guide/ Component Management/ Managing Components/ Rolling Back a Component
Updated on 2025-12-30 GMT+08:00
You can roll back to a historical version and configuration. (A version number is generated for each component configuration. The number is the same as the current one, but the time is different.)
- Log in to CAE.
- Choose Components.
- Select the target component and click More > Roll back in the Operation column.
- Select a rollbak version. Figure 1 Selecting a rollback version
- Confirm the component configuration and code source of the rollback version, and click Roll Back Now. Figure 2 Confirming information
Parent topic: Managing Components
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
