Updated on 2025-12-30 GMT+08:00
Related Operations
After the component is created or deployed, you can view the environment ID, application ID, component ID, component name, code source, status, number of instances, and creation time on the Components page.
On the Components page, you can perform the following operations on created or deployed components:
Table 1 Related operations
Operation
View an environment ID
Mouse over Environment to view the environment name and ID.
View an application ID
Mouse over Application to view the application name and ID.
View a component ID
Mouse over a component to view its name, version, and ID.
Search for a component
Enter a component name in the search box above the component list to search for the component in fuzzy mode.
Refresh the component list
Click in the upper right corner of the component list.
Customize columns
Click in the upper right corner of the component list to show or hide a column.
Filter components
Click in the Code Source or Status column to filter components.
Switch the component sorting
Click in the Name/Version/ID, Last Change Status/Time, or Created column to switch the component sorting. indicates the default sorting order, indicates the ascending order, and indicates the descending order.
Configure a component
Click on the right of a component to go to the component configuration page. For details, see Component Configurations.
View component monitoring
Click on the right of a component to go to the component monitoring page. For details, see Viewing Component Monitoring.
View component logs
Click on the right of a component to go to the component log page. For details, see Viewing Component Logs.
View component events
Click on the right of a component to go to the component event page. For details, see Viewing Component Events.
View change details
Click in the Last Change Status/Time column of a component to view its change history.
