Updated on 2025-12-30 GMT+08:00
Viewing Component Logs
- The page displays up to 500 logs. To view more, go to Log Tank Service (LTS) to view real-time standard output logs.
- The system continues to collect logs beyond the free quota (500 MB). You will be billed for extra logs on a pay-per-use basis. For details, see Pricing Details.
- By default, log data is stored for 30 days. Retained logs are deleted at the end of the duration. For long-term storage, transfer logs to OBS buckets. For details, see Log Transfer.
- You have created an application. For details, see Creating an Application.
- You have created a component. For details, see Creating a Component.
- Log in to CAE.
- Choose Component Logs to view and locate component faults.
- Use the drop-down lists to select environments, applications, components, and component instances, and view component logs.
- The page displays component instance logs in different time dimensions. You can select a time dimension from the drop-down list. CAE also allows you to view component instance logs in a specified time period. Figure 1 Viewing logs
Parent topic: Component O&M
