URL Monitoring
After URL log monitoring is enabled, CAE reports URL routing logs to LTS. You can monitor URL logs of application components using LTS.
- Only environments created after July 30, 2025 support this function.
- Reporting logs to LTS and using the LTS log management function will incur extra fees. For details, see LTS Pricing Details.
If you need to use a custom log group and log stream to monitor URL logs, create a log group and log stream on the LTS console in advance. For details, see Managing Log Groups and Managing Log Streams.
Enabling URL Log Monitoring
- Log in to CAE.
- Choose URL Monitoring.
- Click
to enable URL log monitoring. - Configure the parameters based on Table 1.
Table 1 Parameter descriptions Parameter
Auto
CAE automatically creates a log group and log stream.
Custom
- Log Group: Select the log group you have created on the LTS console from the drop-down list. For details about how to create a log group, see Managing Log Groups.
- Log Stream: Select the log stream you have created on the LTS console from the drop-down list. For details about how to create a log stream, see Managing Log Streams.
- Click OK. The URL monitoring is configured.
- After the configuration is complete, you can click View log-based monitoring to go to the log stream page of the LTS console and view and manage URL logs of application components.
