Maintaining Recipient List
After your application is approved, you need to maintain the list of SPIF recipients online for the subsequent SPIF applications in each quarter.
- Use your account to log in to Huawei Cloud.
- Click Partner Center in the drop-down list of your account name in the upper right corner.
- Choose Benefits > Sales Performance Incentive Fund in the menu on the top.
- On the Application Submission tab page that is displayed by default, find the SPIF benefit and click Maintain Recipient List in the Operation column.
- Click Add on the displayed page. In the displayed Add dialog box, select the accounts of desired account managers and click OK.
If you are unable to locate the person you are looking for, you can create an account for them in Organization > Member Management.
- Click Select Individual HUAWEI ID in the Operation column to select individual HUAWEI IDs for the accounts selected in the previous step.
If the HUAWEI ID you want to select is not listed, you can invite the corresponding person to associate their HUAWEI ID with your partner account in Organization > Dedicated Personnel.
- After the SPIF recipients have been added and the corresponding HUAWEI IDs have been selected for them, click Save. A message is displayed indicating that the recipient list has been updated successfully.
- On the Application Submission tab page, click View Details in the Operation column to view the list of recipients and the change records.
If there is any change to the list, click Maintain Recipient List and update the list.
