Introduction
You can create a BMS in different ways.
| Method | Description |
| You can create a BMS by following the wizard instructions, which is the most common method. In this process, you can customize parameter settings to meet your service requirements. | |
| You can create a BMS that can be quickly provisioned. | |
| You can create a BMS in a DeC if you have high requirements for security compliance. | |
| You can create a BMS in a VPC subnet that another account has shared with you. This allows for more efficient use of network resources and reduces O&M costs. | |
| You can create a private image containing a specific OS and applications and then use it to create a BMS. |
